Question about Icom IC-R10 Handheld Scanner
How can i change frequency display of v68 from channel to frequency display
    Genius:
  • 1,274 Answers
Push the manual button ...hope this helps...
Posted on Mar 16, 2010
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
Hi I have a Cobra 75 WX-ST radio. It is currently displaying radio frequencies instead of channels. How do I correct this.
Push and hold the memory key for 3 seconds to change back to displaying channels instead of frequencies. Do it again and it will go back to frequencies on the display.
If you need anymore help, don't hesitate to email me at rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Mount Vernon, TX
Jan 06, 2011 | Cobra Radio Communications
Frequency changing
Here is a link to the manual http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf
Entering Programming Mode
Press and hold Push to Talk and Monitor for 3 seconds while turning the radio on. The
radio beeps and displays PROG, the channel number flashes, and the frequency
(indicated by FREQ) and code (indicated by CODE) display alternately.
Use the MENU and the + or - keys to change the programming. More detailed instructions are on page 28 of the manual.
Best regards.
Dec 29, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Oct 01, 2009 | Uniden BC350 Base Scanner
How do I program a Regency Z30 scanner?
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you want to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission to wait for the next response, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Jul 10, 2009 | Radio Communications
I dont no how to program my regency z30 scanner
1. Press "MANUAL"
3. Press "ENTER"
If you wish to add more frequencies at this time, got to step 2.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
Apr 07, 2009 | Office Equipment & Supplies
Wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Programming Frequencies
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
accelerate or to slow down the search.
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
Feb 01, 2009 | Radio Communications
Raidoshack 1000 channel scanner
The frequencies probably aren't the same, so you're gonna have to do a little research, but hope this helps.
  1. Turn the scanner off and then back on.
  2. The first thing we'll do is clear all of the frequencies in the bank you'll use to listen to Gwinnett County.
  3. Press the black F button, then press 0, then press the F button again, then press CL, and then press the 1 button.
  4. Enter 000 and then press PGM to enter programming mode starting at channel 0. On the display the P on the left of the first line of the display says you're in programming mode, and the 000 indicates your looking at channel 0.
  5. Press the orange T button to enter trunking mode.
  6. Press the MODE button until Motorola is displayed on line 2 of the display.
  7. Press the PGM button again to begin entering frequencies. You'll enter 24 frequencies total. If you make a mistake while entering a frequency you can press the CL button to delete the last number entered. If you accidently press the PGM button twice while entering frequencies you can press the down arrow to back-up to the previous location.
  8. Enter the first frequency, 854.78750, then press ENT and then press PGM to go to the next channel.
  9. Repeat step #8 for the rest of the frequencies 854.81250, 854.83750, 855.31250, 855.48750, 855.76250, 855.78750, 855.81250, 856.81250, 856.83750, 856.91250, 857.81250, 857.83750, 857.91250, 858.78750, 858.81250, 866.13750, 866.21250, 866.38750, 867.33750, 867.38750, 867.96250, 868.11250, 868.13750, 868.48750.
  10. To double-check that you entered all of the frequencies correctly enter 0 and then the PGM button to go back to the first frequency entered.
  11. Press PGM to go through all 24 frequencies, if you see a mistake enter the correct frequency and then press ENT to save it, continue pressing PGM until you have verified all 24 frequencies.
  12. Next press 0 and then PGM to go back to the first frequency again.
  13. Press the MODE button until you see MO following the channel number on the first line of the display (P000 for example). After MO is displayed press PGM to go to the next frequency.
  14. Repeat step #13 for each of the 24 frequencies.
Mar 07, 2008 | Radio Shack Pro-97 Handheld Scanner
CHANGING FROM FREQUENCY TO CHANNEL MIDLAND 75-822
Some models of the 75-822 do not offer this as a feature. Instructions for it are not included in the manual. I recently encountered a refurbished model packed with a manual such as this. Pressing and holding the "F" button toggles between Channel number and Frequency number display.
Jun 17, 2007 | Midland 75-822 40-Channels Handheld CB...
Icom IC-R10 Handheld Scanner Logo
341 people viewed this question
Top Icom Radio Communications Experts
peter0911
spencer hughey
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
