Question about Engel Freezer 22 Qt. Fridge/Freezer
Condensation outlet keeps freezing up so that the ''frost free'' doesn't work. I have thawed it out several times but it continues to frost up. How can I fix it?
  • 4,793 Answers
Move the box to a warmer place,the outer shell is too cold....hence freezing drain/clogging
Posted on Feb 05, 2010
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Drain plug freezes up and ice builds up in freezer then leaks into frig. How do you keep the drain free from building up?
Use a turkey baster filled with very hot water and flush it several times. That should resolve the problem. Also check the door gasket, if it is leaking, excessive frost would be visible causing more water then the system was designed to handle.
Good Luck,
Gil
Feb 28, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Hi! My kelvinator FN360 frost free freezer's motor is running all the time and it is not freezing inside properly.Occasionally, there is a pop coming from the freezer (most of the items are frozen though)...
check your door seals. warm air leaking in can keep it from reaching it's temp. also, the condensation will collect on the evaporator coils causing them to freeze up. when they do, there is no air flow to cool the rest of the fridge, so the compressor will run constantly trying to reach the set temp. empty it out, thaw out the coils, and check your door seals for leaks. if it still happens, you might have a slow freon leak.
Nov 10, 2009 | Freezers
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Any possibility you can help troubleshoot a larger upright freezer? Our freezer is 3 years old. It sounds like it is working -- I can feel cold air and hear it humming, but as of yesterday it stopped...
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
Jul 25, 2009 | Haier 3.6 cu. ft. / 102 liter Chest...
We have a 20.3 cubic feet Kenmore upright frost free freezer we purchased in May 2003. We noticed the meat was beginning to thaw one afternoon. We hit the quick freeze button and that seemed to fix the...
This sounds like a bad thermostadt, since the quick freeze button does work. But it should be much colder than 32 degrees. It may also be the motor, since it runs for brief periods of time after plugging it back in.
I'd say best bet here is to call a repairman. (sorry...)
May 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Just defrosted my freezer and is akll frosted over
When you say it is frosted over, do you mean the interior of the freezer is frosted, or the evaporator coils?
A couple things to check for:
1. Is the door gasket making a good seal when you close the door? A good quick fix for a bad seal on the gasket is to rub a thin layer of Vaseline (the original jelly kind works best) on the rubber to help it stick and to fill any scratches that might be keeping it from sealing tightly.
2. Is the fan running on the inside of the freezer? The evaporator coil in the freezer needs a fan to blow air over the coils to keep them from freezing over. They don't run continuously, and on some units will turn off when the door is open, so try holding the door switch shut when you check.
3. Is the defrost cycle working? Frost-free freezers have a defrost cycle in which a small heater turns on to thaw any frost that has begun to form. To check the functionality of the heater and the defrost timer will probably require a visit from a technician... It would take a while to explain it here, but if check the first two and come up empty handed, post back. You will need a volt/ohm meter.
I would check the first two
Mar 24, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Whirlpool upright frost free freezer
over charging can certainly keep it from freezing depending on the pressures how much it is overcharged the sealed systems on whirlpools have a five year warranty with your history id call whirlpool cust relations and discuss this problem with them they will help not customer assistance cust relations they are different talk highly of their product and tell them you think you just got a lemon thats all and it hasn't ever worked right now Whirlpool cares about their customers most people believe that the factories just build things to last till the warranty runs out that's not true they want you happy with their product on average one unhappy customer will tell 20 people and that's bad for business they would be happy if you never had a problem with their stuff so give them a call tell your mom had Whirlpool your granny had whirlpool you got your whole kitchen whirlpool this is the first Whirlpool you've had a problem with so you think it just must be a bad unit let me know what they tell you now that's customer relations you want to call ok
Feb 20, 2008 | Freezers
Engel Freezer 22 Qt. Fridge/Freezer Logo
146 people viewed this question
Top Engel Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
John Tripp
John Tripp
Are you an Engel Freezer Expert? Answer questions, earn points and help others
