Question about GE JVM1640 Microwave Oven
Question re: installation of turntable motor
Hi. Have a GE microwave model #JVM1640WB007. Turntable quit, bought new motor, installed it. Everythink OK EXCEPT--I can't remember which way the wires attach. Does it matter? I don't want to do it wrong and ruin the motor. So, can you tell me, with the motor screwed into place, does the orange wire attach to the left or right terminal? Please help--I am hungry and can't heat up my soup 'til I get it fixed! :-)
Thanks so much--Les
  • 2,130 Answers
If its an AC motor, the wiring will not matter. Look at the numbers on the motor. You will see a voltage rating, RPM rating and if you see the text "50/60 Hz" it is an AC motor and the wiring will not matter.
If its a DC motor, you will see a voltage rating, RPM rating and a + & - for the wiring. If you reverse the wiring, the turntable will turn in the opposite direction.
I'm not sure about all microwave ovens, but the ones I have worked on, the turntable turns in the clockwise direction.
Most likely, its an AC motor. Look for the "50/60" text. If its an AC motor, the wiring will not matter.
Please let me know if I can be of further assistance to you,
- Jim
Posted on Feb 21, 2008
The turntable doesn't turn.Will using the microwave until I can replace the motor harm anything?
If the turntable platform has wheels sometimes they accumulated grease or other material that gums them up. This will cause the turntable to lurch and/or jump during rotation.
Remove the platform and soak it in hot soapy water taking care to clean each wheel.
Rinse, dry and re-install the platform.
Jan 20, 2015 | GE Spacemaker JVM1750 Microwave Oven
Why wont my GE Spacemaker JVM1650 turntable wont work?
replace the turntable synchronous motor
look to ebay search for
ge jvm1650
then add turntable motor or browse down youll find a new motor
the coils inside may be duff
Aug 12, 2014 | GE Profile Spacemaker Over-the-Range...
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
Microwave turntable motor or belt?
I assume you don't have an illustrated parts list try and Google one up using make and model number etc. It is also a good guide on what needt to be removed and in what sequence.
As far as the novice part, the turntable is a basket case now what can you hurt, this is how we all learned, try to fix it if you cant then call someone who can, not a big deal.
Feb 28, 2009 | GE XL1800 1100 Watts Microwave Oven
My turntable stopped running
If you didn't buy the turntable motor then I assume you purchased the coupler ( white plastic/nylon piece that fits into the turntable motor collar and rotates the platen? Is that what you purchased?
Sep 13, 2008 | GE JES1384SF Microwave Oven
GE turntable microwave Je1540WW 002 Turntable doesn't turn
I have had the turn table motor go defective in microwave ovens.
Normaly, before ordering a new motor, I always checked to make sure that there was power going to the motor assembly. I never had a power drive failure to a motor so-far. When they did not spin, the motor was defective. But, one day there will be a first time for me.
The fix was to purchase a new motor from the manufacture and install it. In some cases, I had to also replace the spindle key because the original broke when trying to remove it when removing the motor assembly.
I suggest that for servicing a microwave oven, you give it out to a service center to have the work done. There are safety issues when working on microwave ovens.
Jerry G.
May 25, 2008 | Microwave Ovens
Turntable repair? GE Profile model JVM1660BB
IF EVERYTHING IN THE OVEN IS WORKING BUT THE TURNTABLE YOU HAVE TO TAKE THE BOTTOM COVER OFF THE OVEN THE MOTOR HAS TWO WIRES ON IT, BE CAREFULL
WHEN YOU TEST IT AS THERE IS 110V ON THE WIRES.IF THE 110V IS THERE BUT THE MOTOR ISN,T RUNNING TAKE THE
TWO WIRES OFF,AND TAKE THE MOTOR OUT AND BUY A NEW ONE. YOU CAN DO THIS BUT DO BE CAREFULL.. YOU
MAY HAVE TO PULL ON IT A LITTLE TO PULL IT APART FROM THE PEACE INSIDE THAT TURNS THE GLASS TRY NOT TO BREAK IT!
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable Grinding Noise
It will need a new turntable motor. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 21, 2007 | GE JVM1660 Microwave Oven
GE Spacemaker XL 1800 Turntable malfunction?
You can find helpful exploded views and buy the replacement turntable motor at http://tinyurl.com/gv383 Need safety tips? See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM2070 Microwave Oven
GE JVM1640 Microwave Oven Logo
103 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
