Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Box shwing p603 and flashing
Box showing p603 and flashing, when i press any button on remote er09 shows.
5 Suggested Answers
SOURCE: Hi :-) I also have P603 / Er09 / Er07 / 00-- Error
contact sagem 0835 0900316 technical support helpline you will need serial number of your box and the model a new power adapter was all I needed and can now watch all the programmes i had on the disc and thought i had lost
helen april 2010
Posted on Apr 07, 2010
SOURCE: my HD PVR 101-ST has an error code: Er09 when i
Hi, just got the same problem.
In my case it started not working well 4 days ago. Today I got a message on the screen asking whether I wanted to upgrade the software. I did and now I have this problem.
In my case I would say that canal digital customer service is quite bad
Posted on Jun 07, 2010
SOURCE: Shows ER07 ER09 ER 01
I had a very similar problem. On initially starting up it showed Pb03 then would cycle between er07 er09, er01 and counting up 00,01 up to 19 or so.
Nothing I did fixed it including turning it off for a long period and back on without the aerial.
Eventually I fixed it by pulling out the power cable while it was counting up and then on powering back up it started to initialise correctly. No idea what the problem was and why this fixed it but it might be worth a go. It didn't involve losing any recordings.
Posted on Feb 07, 2011
SOURCE: I have sagem DVR6200T/6400T which is giving me
I have a Sagem 6200T/6400T when changing to another channel the lights went out on the box and I cannot get them back
Posted on Apr 04, 2011
Shows ER07 ER09 ER 01 Scrolls through 01 etc. and eventually shows ER09 SAGEM Model DVR 6200T/6400T
Jul 26, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
My HD PVR 101-ST has an error code: Er09 when i press th ''ok'' button it shows Er01 when i press ''ok'' it shows 00-- and after a while it shows ER09 again. If i pull the power cord it starts the same...
Apr 25, 2010 | Televison & Video
My box sagem pvr 6240 stop suddenly and started to flashing er09, l turned off for 2 hours and when l restart it shows pb03 and change and keeping flashing er09. I have manipulated the buttons, pushing...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Sep 07, 2017 | Sagem PVR 6280 Freeview DTV Receiver /...
Er09 and Er07 black screened
Turn off the unit for 15 mins.
Turn back on with eveything connected except the antenna.
You will get an er 09 on the display.
Press OK on the remote.
With a bit of luck the box will reboot into standby.
Connect antenna and see how you get on.
Jan 07, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Hi :-) I also have P603 / Er09 / Er07 / 00-- Error messages, even after being unplugged overnight. Upon power application the unit clicks quite loudly 10 times in a row, then repeats this 4 times, before...
helen april 2010
Oct 11, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
My sagem DVR 6200T UK is now displaying when switched on P603 then it goes to ER07 this started last night.There seems to be no signal to the TV from the set top box and the remote wont work! i have...
Hi I had the same problem P603, er07 and er09, solved it by buying a 12v adaptor, you dont have to use sagem, in fact they are not very helpful, they will only take credit cards and it will cost you £15.00, any 12v adaptor will do. Mine is working perfectly now
Sep 26, 2009 | Televison & Video
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Sagem freeview not working - says error 09
Unplug the box, leave for a couple of minutes, remove the antenna, and plug the box back in.
The display will show 00--. this cmay take a couple of minutes so wait until the box shows ER09.
When this happens, Press the ok button.
The box will reboot, and a messege will say the download was succesful
The box should now work, and may need retuning. it will take some time and rescan and when it finishes, it will probabably ask for a resacn again, select ok and it should now do it again,
Mine toppled over yesterday and it is now all ok
Jul 17, 2008 | Televison & Video
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
512 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
