Question about Viking DDSB483 Side by Side Refrigerator
Low temperature in freezer and refrigerator - Viking DDSB483 Side by Side Refrigerator
1998 GT22DKXGN00 refrigerator freezes, where is thermostat in refrigerator ? This is a Whirlpool
Check refrigerator and freezer temperature. If the freezer is above 0 degrees Fahrenheit it is likely the cooling capacity of the unit has reduced due to low charge or weak compressor. What usually happens is that the freezer is not able to reach the proper temperature and the unit runs continuously. The result is that the refrigerator via the freezer-refrigerator air flow connection freezes.
"This is not intuitive", but the logic is that from the compressor running continuously the freezing air that flows into the refrigerator side results in that the refrigerator will freeze,.
Check the temperatures. If the freezer is above 10 degrees F it is almost certianty the cooling capacity has been reduced.
If equipped with an ice maker the output of the ice-maker will also reduce with this problem
It is possible to have the compressor replaced but not usually cost effective.
Apr 10, 2017 | Refrigerators
Why is the temperature fluctuating.
Service engeener always checks the average temperature inside freezer or refrigerator compartment. When you turn on freezer, the compressor starts to circulate gas through the system and the temperature in the freezer is decreasing (go to minus). When inside of the freezer reaches the set temperature the compressor is switched off and temperature will increasing. What will be the difference of inside temperature depends on the type of refrigerator and type of thermostat or sensor and moves to max. 8-9 degrees. With the advent of new "No Frost" refrigerator, this difference was reduced to only a few degrees Celsius, thanks to the fan inside the refrigerator and NTC sensor.
So 29 + 14 = 43; 43/2 = 21.5 which means that your average temperature of -21.5 which is not too much deviation from the set temperature of -18 and I think that is ok.
Dado
Jun 13, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Clicking noise, ice maker out, freezer temp high
Low temperatures are absolutely required for proper operation of ice makers components. Dirty cooling coils or possible low refrigerant.
Jul 08, 2009 | Freezers
THERMOSTAT
Hi, Here is the Part # 5304421256.
This is a common issue with this model. Just remove the 4 screws holding the control panel up and you will be able to see the thermostat/cold control
I hope this helps you.
Please let me know if I can assist you further.
Vicl
Jul 05, 2009 | Frigidaire FRT17G4B Top Freezer...
What do you do to convert a T49F freezer to run as a refrigerator and is this feasible?
First of all the unit uses a low temperature compressor which is designed to work on a freezer. Refrigerators use a medium temperature compressor. So most likely it would be over sized for what you are trying to accomplish,
Secondly the evaporator feed device is designed for "low temperature", not "medium temperature", so it would involve resizing the feed device.
May 27, 2009 | True Freezer T49DTG Stainless Steel
Frig freezer bosch kgv3120gb/01 with the thermostat set at no 5 the temperature in the freezer compartment is only minus 5
Hello button7
Welcome,
How old is your unit?
  1. Check if your freezer is packed so full that you have articles covering the air vents found in the rear of most freezers.
  2. This would restrict the cold air from circulating between the freezer and fridge compartments ,thus inconsistent temperatures may arise!
In today's refrigerator / freezers they share the air in a circulation process.
Or you may have this problem
Low refrigerant change
If the unit has a low refrigerant change, the freezer will not reach proper temperatures. This must be checked by a qualified technician due to EPA regulations.
Let me know how you do!
Thank You for using our site,
Huuum
Please remember to leave a rating!
Oct 14, 2008 | Bosch Refrigerators
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Viking DDSB483 Side by Side Refrigerator Logo
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Jim Y
Jim Y
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
