Question about Schlage BE365-CAM BE365CAM505 Lifetime Polished Brass Electronic Security K
How do you erase an old code and input a new code?
    Sniper:
  • 82 Answers
Programming info at http://dl.owneriq.net/a/a8480104-048d-488f-8efb-03836644d506.pdf
More manuals etc located at http://homeappliance.manualsonline.com/manuals/mfg/schlage/be365.html
If this helps pls leave feedback
Posted on Feb 05, 2010
2004 Ram 2500 starts, low idle 400 rpm and stalls, any ideas?
With out see it running on a scanner. Maybe the IAC or throttle body. Does it have any codes. Did you erase codes after rebuild? Any time I do a rebuild on engines and transmission, the codes have to to erased. Other wise you are trying to run a new part on old PCM codes. Codes have to be erased.
Dec 13, 2016 | 2004 Dodge Ram 2500
My Linear garage door keypad has two codes that will open and I want to change to only one
I don't think you can erase the old code. Get on their website and see. Try calling them and asking the question. I think there is a way you can erase all the codes and then start over.
Dec 17, 2017 | Home Security
Reset new codes and old existing codes won't erase,the original code from last year still works, even after installing 2 new codes
Here's the link to the online instructions:
http://www.weiserlock.com/PDFS/instructions/Electronics/Powerbolt.pdf
Programming instructions are on page 6. Notice that allowing too much time between inputs will be a problem.
If you cannot successfully override your existing codes, contact Weiserlock Customer service:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
A note about PDF files: You will need adobe Reader or equivalent installed if you are unable to view the instructions. http://get.adobe.com/reader/
Nov 03, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do I clear (erase) all codes from my Weiser Powerbolt 1000 in order to start with fresh entries? Adding new codes does NOT override/delete old existing codes as page 7 of my manual indicates. I now...
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Good luck, Elizabeth!
Jul 26, 2011 | Weiser Lock Powerbolt 1000 Lock
I have added a new email address to Facebook but it did not erase my old 1, how can I erase old 1.
you can not erase old email id but you can hidden your email id please click on edit profile /setting/privacy setting and you can erase old id......
Jul 06, 2011 | Computers & Internet
Two codes open door
You must hold that red button in for 6 seconds to erase the memory. Just remember you will have to program your hand remotes plus the wireless keypad.
Aug 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
I lost my keys for my 2003 rodeo
you will have to get a dealer to cut new keys to code that dealers have access to and then get them to program to car but also erase old keys so vehicle wont start with old keys
or next more expensive option is new keys, ignition barrel and door barrels replaced which are differently same coded key and locks as well as programming and erasing old keys.
Jun 27, 2009 | 2003 Isuzu Rodeo
2002 Boxster - Trouble with the radio code. I
what is code for my radio in my porsche boxster 2002 2.3. I took off my car battery / my radio will not turn on now... please help me
Apr 05, 2009 | 2002 Porsche Boxster
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Code po455
Check your fuel cap. You may have to buy a new one in some cases because the seal on the old one has gone bad. Before you buy a new one though.... Tighten the old one and try to erase the code is it doesn't go out by itself.
Jan 23, 2009 | 2000 Dodge Ram 1500 Truck
Schlage BE365-CAM  BE365CAM505 Lifetime Polished Brass Electronic Security K Logo
16,891 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
