Question about Philips Televison & Video
Hi! I have a used CRT TV Mod. 28PT4457/01. The TV channels behave as they should, but I cannot get any signal to the display from neither the Video (antenna cable to Video/In, Antenna cable from Video/Out to TV), nor from the DVD connected to the TV with Eurocable ("SCART"). I have tried both EXT1 and EXT2 on the TV for the DVD. - I have tried the tips in the User's Manual. - Is there something NOT obvious that I should try? Regards, Mats
  • Philips Master
  • 19,396 Answers
Hi.
The only non-obvious thing to check from user level point of view is the PAL/NTSC settings on TV and devices, but if the TV is in use on the country of purchase, and if you get the same problem using different devices, then this should not be the problem.
If the TV does not display any input, and you are sure that the source/input selector button on remote is working, then the TV has a fault signal board, that on this models should be integrated on the digital board. The TV in that case must be fixed by a technician.
Try connecting the DVD directly (bypassing cable box), using a SCART that you know is working. If you cannot see the DVD display after selecting EXT1 and EXT2 , then it is a faulty signal input on TV.
Ensure that the problem are not cables.
Try also the following:
  1. Disconnect TV power cord.
  2. Disconnect DVD power cord.
  3. Connect DVD using SCART on EXT1.
  4. Connect again power cords.
  5. Turn DVD on.
  6. Turn TV on two minutes after DVD is on.
If yous still cannot watch the DVD signal, then the TV is faulty.
Regards.
G.
Posted on Feb 05, 2010
Testimonial: "Don't worry. Your reply reflected deep knowledge in the matter. I did not want to offend you. I was disappointed to have to accept the TV is faulty./M"
  • Ginko
    Ginko Feb 05, 2010
    Hi.
    I noticed that you left a negative feedback, I am sorry about that.
    I did my best to give you a professional opinion. I am sorry that this did not solve the problem. Your fee should have refunded already.
    I will be grateful if you can change the negative rating given. That does not affect your right to refund, but only hurts the professional assisting you.
    Goodbye.
    G.
  • Ginko
    Ginko Feb 05, 2010
    Thanks.
    G.
How do I put it on channel 3?
If you are asking about using a standard CRT Monitor with some device that has a Channel 3 TV output, you have to either have a tv tuner device between your monitor and the device you want to connect to, or find video outputs on the device other than the TV channel out in order to connect to a monitor. Monitors work with video signals. TV's work with radio signals. These two inputs are not the same thing. Channel 3 is a specific radio frequency signal that must be converted to video to be displayed by a TV. Computer monitors do not have the circuitry installed to convert radio frequency signals to video. Therefore, strictly speaking, there is no easy way to 'put' a CRT Monitor 'on channel three'.
Apr 25, 2015 | Televison & Video
Sony TV problem.
Chances are the CRT has expired. In that case I would recommend replacing the entire unit.
Mar 06, 2008 | Video Game Consoles & Games
I have a sharp crt tv model:25c-bs370,although i'm using cable signal which more than 100 channels,still the channel it receive is limited only to 35 channels...how to rechannel the unit?my tv came...
Hi,The Television from japan have no lowband channel,It can be rechannel but the channel additional is onlly the lowband channel it maybe add only 2 channel.So the best things you do is to buy and install a channel converter to your TV.A channel converter is 100 plus channel thats why you can use your cable to japan television.To install the channel converter you need to set your television to Video setting and use RCA connector and plug it to video/sound input of your TV and video/sound output of channel converter.The cable connected plug it to channel converter.
Jul 11, 2011 | Sharp Televison & Video
Cant get game to come on
On the old TVs, to display a video signal the TV must be tuned to Channel 3 or Channel 4. Some TV have the video channel on Channel1.
Connect the console to the TV, tune the TV to Ch 3 and then to CH4 to find out out which is the video (or auxiliary input) channel.
Dec 30, 2009 | Philips Televison & Video
I HAVE A SAMSUNG MOD. NO TC9823S, LOST REMOTE I WANT TO HOOK A DVD UP ON THIS TV, CANT FIND INPUT CHANNEL, CAN YOU HELP
You need a RF Modulator that outs the signal into the cable input because the TV has only a video input (yellow) but no audio in, only audio out. Radio shack has one for about 29 dollars.
Mar 22, 2009 | Sanyo DS31520 31" TV
Zenith B25A10Z connected to a DVD player via modulator. We use verzon STB. Dvd will not display on TV when turned on. Remote a/v does nothing. Any help?
If you are using a modulator, usually that sends a signal to channel 3 or 4. Select either 3 or 4 and you should get the signal. The modulator should have a switch to enable you to select one of those channels. Selecting the Video input is when the DVD is connected using the audio and video cables (Red/White/Yellow)
Dan
Jul 29, 2008 | Zenith B25A10Z 25" TV
Channel switches on it's own
This is probably a sticking button, similar IR signal from another remote control, or simply a short on the system board that holds the controls.  A simple cleaning might take care of this.
Oct 19, 2007 | Sharp 32U-F810 32" TV
Have sound and OSD but no picture
You may have a problem with the video switching IC. Stargazer
Aug 18, 2007 | RCA F27665 27" TV
Televison & Video Logo
118 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
