Question about Dell Latitude D510 Notebook
The battery indicator on my laptop keeps flashing unusually
The battery indicator on my laptop keeps flashing upon its complete recharging. The flashing comprises 5 flashes, 4 red and 1 final yellow as usual. The battery meter shows the battery is fully charged. Thanks for help.
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 86 Answers
Try to upgrade the bios you can download it on the support site of dell which is www.support.dell.com
ERNZ
Posted on Feb 05, 2010
Eliminator power box is not charging and the battery green status light keeps clicking and flashing on.What is the solution. Thanks
Switch off power completely , remove the battery and re-insert the battery completely locking it into its place and then connect the Eliminator - if the status light is steady and indicates its charging your problem is resolved else change the battery.
Jun 16, 2015 | Computers & Internet
Tip
Battery failure indications
Following are a few reasons that indicates a battery failure:
  • The usable time after recharging is shortened.
  • The battery becomes unusually warm during a recharge cycle.
  • The battery becomes unusually warm during phone use.
  • The battery case often is swollen. This is detectable by feeling and viewing the inside/phone-side of the battery case. Also, when the battery is placed inside/phone-side down on a flat, smooth surface, it will rock and will sustain a spin motion. The case of a healthy battery is flat and will not sustain a spin motion.
  • The battery develops a hard spot. This is detectable on the inside/phone-side surface of the battery by gently pinching about the surface between one's fingers.
on Aug 07, 2010 | Cell Phones
Tip
Samsung SL202 Flashing Yellow Light Is your Samsung SL202 flashing a yellow...
Is your Samsung SL202 flashing a yellow light and not charging its battery?
This is an indication that your camera has decided it needs to completely discharge its battery before the charge cycle begins it again.
Rechargeable batteries last longer and perform better when they are completely discharged before being recharged. This is normal.
I hope that helps.
______________________________
SL202 User Manual here.
SL202 QuickStart Manual here.
on Apr 18, 2010 | Samsung SL202 Digital Camera
Undervoltage battery indicator on a mercedes c240 keeps flashing and e know that my battwry is not being recharged
check the charge rate by putting volt meter across battery with engine running if between 13 - 14 volts alternator ok ,the ecu is a completely different part to the charging system , then check if battery is holding charge at a garage
Mar 31, 2014 | Mercedes-Benz C-Class Cars & Trucks
After battery replacement, upon power up, constant beep with fault light full on and battery light flashing. On some trys, the bypass light will also light up. No response from buttons. Unit is...
Try and push and hold the on button for about 3 sec. This will start a manual battery test. If only three of the five battery led illuminate allow the ups to recharge the batteries for 24 hours. Battery light flashing means internal battery source not available. Check battery connection, completely power down and reboot UPS
Sep 06, 2011 | Liebert UPStation GXT1000RT...
Why does the battery light keep flashing?
The battery is failing to recharge itself.
Contact Dell -- a battery should last longer than that.
Dec 08, 2009 | Dell Latitude D600 Notebook
I've a dell inspiron 1521 battery problem
The battery has an internal failure (Most likely a bad cell) While the battery works, the resolution for the LED indication is to replace the battery. Batteries are a consumable item and generally, batteries have a life of 300 to 500 recharge/discharge cycles before replacement is necessary.
Oct 17, 2009 | Dell Computers & Internet
Battery Light Flashes Orange and Green
The LED sequence indicates a failure in the battery. (Like one cell has low charge) As long as the overall battery output meets the minimum for system operation, the battery will work.
The average lifespan for a Portable battery is about 500 discharge/recharge cycles (1 to 2 years) anything after that is a bonus
Replace the battery, issue will go away
Nov 18, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude D510 Notebook Logo
158 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
