Question about Water Heaters
The boiler was fine this AM but suddenly we have got a code 03 error. Tried Reset as suggested in the manual. I can hear the fan running when I switch the mode selector switch is in the off position.
  • dave577 Feb 05, 2010
    Yep sorry but I had been looking at the Vokera Linea 24 butr stupid me didn't put that in the question did I!!! Thanks for getting back to me so quickly. Dave.
    Thanks for the help - I'll give it a go. Thanks again, Dave
  • 3,230 Answers
Well can you please tell us the Brand and the Model number of your Boiler...... so we can help you in details......
Thanks
Posted on Feb 05, 2010
  • Mukesh Kumar Feb 05, 2010
    sorry for late reply......... well the error code sounds like air in the system,
    vent all rads, and re pressure the system again.
I have a sime ecomfort boiler.. And no hot water.nit is showing code AL01. We have tried to reset a number of times and error code is still showing. Can anyone suggest any fixes?
The Sime documentation says for AL01 you need to "Request assistance from qualified technical personnel." Not really helpful.
Nov 01, 2014 | Water Heaters
AMTROL Boiler Mate no hot water
You might have bad faucet cartridge or check valve.
Possibly a clogged line.
Contact amtrol info@amtrol.com to hear them suggest calling local technician
Otherwise Amtrol does not post service information or service manuals.
Post question on pro water heater forum to hear them suggest a few things before you call local service technician.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Use search feature on forum above, before calling local service technician
Read suggested answers at fixya before calling local plumber.
Call amtrol and ask why they do not post service manuals or service information when so many promoters are selling the product.
May 17, 2013 | Water Heaters
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
What does error codes e34 and d65 mean on ariston boilers
You need to service the boiler and more likely to remove the restriction ring in flue, as only serving not always work or work only for short period, as boiler get older it is struggle to move exhaust gases out from burning chamber so it need good clean for fan, heat exchange , and there is restriction ring just befor L bow which need to remove so gases can flow better.
Jan 16, 2012 | Water Heaters
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
My ariston boiler is not working it just shows A 01 have reset but still nothing any ideas?
Basic checks:-
water pressure in boiler
gas supply on
Turn boiler on then:-
does the fan come on - u can hear this at the top of boiler
does the gas valve click on
has there been a burning smell near the lower front [check the pcb]
check the co-axial flue is ok with no gaps between inner & outer [rare but not unknown]
If it's a condensating boiler check the condensate outlet tube for ice blockage especially in current weather
Dec 27, 2009 | Water Heaters
Boiler problems
heres a copy of the serviceing manuel for the unit. just click on the link and download the manual. http://www.ariston.co.uk/uploads/doc482c2cada6e71.pdf good luck
Jan 11, 2009 | Water Heaters
Water Heaters Logo
23 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
