Question about Zenith L13V36 13" Flat Panel LCD Monitor
My crt monitor has been displaying horizontally coloured lines.iam chechking all the cables but it is ouite right now pls help me
  • 316 Answers
Hello,this is vertical IC loose connection. The vertical output components either a transistor or an IC is probaly got a bad solder joint. Also another possibility is the deflection pins. Buy soldering iron and solder from electronic work to repair the connections.Take the back off of it after it is unlpugged and disconnected from the computer and check the bottom of the circuit board for bad solder joints.I recommend you to be serviced by a technician.
Posted on Feb 05, 2010
My LG monitor E700S displays yellowing colour instaed of white. Pls suggest
please try to change the rgb cable /and before try to connect the cable properly to the graphics card and all the pins i good.also go to the menu of the monitor and set the colour temprature to cool .its should be good
thanks
Dec 10, 2010 | LG Studioworks 700S 17" CRT Monitor
Yellowish colour of the monitor
check the datad cable of monitor, if ok.then soldring may be dry ot the CRT neck
Jul 29, 2009 | Samsung 793S 17" CRT Monitor
No power into my crt monitor samsung
first disconnect the path of EHT then check voltages if present then open H o/p transistor check it if faulty then replace it if not then EHT is faulty replace it also check IRF630 mosfet if faulty replace it
Nov 04, 2008 | LG Studioworks 563N 15" CRT Monitor
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
Monitor No display
1. Power is comming or not.
2.Check Horizontal Transistor.
3. Disply cable. 1,2,3, pins & 13, 14 pins continuty.
4. Filament supply , drypoints in neck board.
5. filament supply diode, capacitor.
Oct 23, 2008 | Samsung SyncMaster 551 15" CRT Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor displays only horizontal line
hey bro.
you try to re solder the vertical section and the color section.
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Zenith L13V36 13" Flat Panel LCD Monitor Logo
87 people viewed this question
Top Zenith Computers & Internet Experts
Are you a Zenith Computer and Internet Expert? Answer questions, earn points and help others
