Problem for Washing Machines
Generic problem for all Washing Machines
Drum not turning
Same Problem
Jan 06, 2009
-   I have same problem too. I have a Bosch Maxx.
Suddenly drum doesn't turn but timer is clicking as if it's reading the wash programme OK.
It's not a clog because I can fill and drain the machine on any wash or rinse setting just fine. The drum just doesn't turn to wash, rinse or spin.
Someone on another forum suggested the carbon brushes. If anyone has a DIY solution to enable to to find these brushes and replace then, that would be brill. -
cmma01 Aug 17, 2008
-   Everything is working on the machine and it sounds like it is operating, but drum is not turning. Belt is connected properly, i've cleared outlet pipe....water is running through machine as it should for washing cycles, but still the drum is not turning. When i move belt and drum it turns easily, but just not when machine has to operate itself??? P.S.: I have the washer/tumble dryer combo front load machine and even the tumble dry section is working, but without the drum turning??? Help!!! ;-(-   Guest Jun 15, 2008
-   my zanussi iz141w dosent spin, it it will do everything else just no spin-
rodders36 May 10, 2008
-   I have a hotpoint aquarius extra WMA34 and the drum has stopped spinning, it appears to fill and drain ok but makes a buzzing/cracking noise when due to spin but then does nothing. Any help would be greatly appreciated.-
loulou69
Solution #1
posted on Feb 24, 2008
Rank: Guru
Expert
Rating: 93%, 3355 votes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Popular Solutions for Washing Machines
Maytag Neptune MAH5500B Front Load Washer
1 Solution
Whirlpool Ultimate Care II LSQ9549L Top Load Washer
1 Solution
Whirlpool Ultimate Care II LSQ9564J Top Load Washer
1 Solution
Questions and Unsolved Problems for Washing Machines
I am looking for the largest front loader washing machine. I do not want a lot of options just...
(More)
I am looking for the largest front loader washing machine. I do not want a lot of options just plain and simple.
Which are the best front load washer and dryers?
samsung wf337aar washe will not drain is there a repair manual availabe?
When I open the washer at the end of the cycle, lots of water pours off the lid on to the clothes...
(More)
When I open the washer at the end of the cycle, lots of water pours off the lid on to the clothes and water is in the bleach dispenser and the fabric softener dispenser
the washer is flash f 20,what does that mean?
