Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
Parts for duel flush
I WORK AS A MAINTENANCE AT HERITAGE RETIREMENT HOME SO FAR i REPLACE 20% OF TOILET,NOW i STOP BECAUSE i HAVE COUPLE HANDLE BROKEN AND SOME FLAPS DO NOT WORK UNDER PRESURE AND WHEN i ASK home DEPO THEY TOLD THEY DONT CARY A PARTS , THIS IS REDICULES IT IS LIKE SALLING A CAR WITHOUT A GAS TANK. i WANT SOLUTION BEFORE i CONTINUE ANY MORE REPLACEMENT.
  • 3,600 Answers
Your going to the wrong store instead of home depot Try Ace hardware they will have the parts you need there.Also some of the new toilets have a flapper valve that has a hole in them and they don't work very good so replace the flapper valve with one without a hole in the flapper and one that has a float on it this way the float will hold the toilet open long enough to flush and not stop in the middle of flushing. The handle should be a standard handle. If you need more help ask and I will give you more information.
Posted on Feb 05, 2010
Toilet won't flush.
How modern is the toilet?
Sometimes the flush handle chain or strap falls off. This can easily be reattached or replaced.
On older toilets the flapper valve can easily be replaced.
Your local hardware or home centre store should be able to provide parts.
Apr 26, 2016 | Home
Bemis duel flush toilet leaking, how do I fix it?
If the leak is inside the toilet, then you have a defective flush valve or flapper Which ever one is in your model toilet.
Jul 25, 2014 | Bemis Home
Hi all, I have a Jacuzzi SWP-1 Perfecto Dual
Hi, Go to amazon and look for replacement parts.... here:
Jacuzzi SWP2959 Perfecta Dual Flush Two Piece Elongated Comfort Height... I hope this was helpful.
Mike
Aug 15, 2013 | Jacuzzi Home
Cistern water won't fill to line
Yes it could be. Bend the rod that holds the ball into the water. This should do it. As far as the fill line. It is not imperative that it fills to the line. In fact it uses more water to do so. This is going to save you water anyway. Adjust your chain that lifts the flapper a little shorter so that it lifts the flapper up higher. This will stop you from having to flush the handle several times. Let me know if this works.
Feb 20, 2013 | Home
Where can I find replacement parts?
home depot etc, most hardware stores.
Mar 30, 2012 | Home
I have a broken oblong duel flush toilet button. I carn't find a replacement. All the replacement buttons appear to be round. I do not know the toilet make.
Unscrew handle, most likely has left hand threads. Take off & bring to either Home Depot or Lowes near you & they will have or be able to get you the correct one.
Jan 17, 2011 | Plumbing
Flush handle is broken how do i get replacement parts its a two way flush
any home repair ,plumbing and most hardware stores carry repair / replacement parts
May 17, 2010 | Pegasus Technologies Two-Piece Round...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Water want stop pouring
remove lid from tank.see that 'flapper valve' in bottom of tank is seating to stop flow into bowl.adjust chain linking flapper to flush handle. replace worn or broken parts
Oct 01, 2009 | Toto Toilet Onepiece Ultramax ...
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
177 people viewed this question
Top Pegasus Technologies Home Experts
john h
paulcarew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
