Question about Watches
I purchased the watch 4 days ago it wil work for so long then stops some times it will re start with just a shake other times it needs the time changing to restart
  • 2,334 Answers
All the things you mentioned are pointing to the FAULTY watch movement. See the seller of the watch and ask to replace it with the new one. There are hundreds of causes that can stop the watch, but in your case there is no doubt - watch movement is faulty.
Posted on Feb 05, 2010
My watch was purchased just 4 months ago...It has been working great...it has "watch hands" and a digital read out as well...the watch hands have been running slow the last couple of days and I...
the batetery is the problem of your watch, it has to be replaced. even it is only 4 months after purchasing it it may be sat in selling showcases for a long time. if you have any warranty you can bring it back from where you had purchased it. i hpoe I had been helped you.
Jul 23, 2011 | Watches
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Mar 08, 2011 | Jacques Lemans Classic Automatic...
The second hand will not re-set to zero. It has stopped. The watch works perfectly during the day apart from the second hand not moving, but , the watch stops at 11.15 at night. When I get up in the...
This is a symptom of what is usually several possible issues:
1) The most common is that the battery must be changed. Insist on Energizer batteries only (as they do not leak) and visit your local Certified Master Horologist for assistance in changing the battery and resetting the watch.
2) The movement must be serviced every 3-5 years by a qualified professional. Dust and debris can cause the symptom of stopping and starting the movement. If you have owned it for less time than this, remember that the watch may have been manufactured and in the retail location longer than this period of time before it was purchased.
3) The movement is defective or damaged. If the watch is under warranty, and it was purchased through an authorized dealer, Armani will take care of this issue for you at no charge.
To properly assess this issue, I recommend taking the first step, as a CMH also has the proper tools to test the movement and battery to determine the best next course of action.
watchandpen
Feb 25, 2011 | Giorgio Armani Emporio Armani watches...
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know...
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Oct 14, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
Tag Heuer 2000 Automatic not moving
Sounds like your watch is in need of service. All watches need to be maintained and regular service is required. A watch is a tiny machine. So if you think about it a car needs regular maintenance to keep it running and so will any machine.
In a watch the oils dry out after about 3-5 years and they stop lubricating. Just like in a car when the oils stop lubricating the engine will stop, a watch will stop.
The reasons for this are 1) no lubrication means high friction on the moving parts. 2) the dried oils become gummy like glue and hold the gear train in place which keep the gears from moving.
The only answer is to have your watch serviced to get rid of the old lubrication, clean and replace any worn parts, then reassemble and lubricate, and finally adjust the timing.
This is something only a watchmaker should do as the parts in your watch are very small and very fragile. Improper handling can permanently damage the parts.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 24, 2010 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Hi my tag heuer monaco has stopped working but when i wind it to the correct time it starts again for a while, what is wrong with it
I'm sure its an automatic - next time it stops do not set time just shake it and see it if starts again - automatics need to be worn most of the day to last during the night
Mar 04, 2010 | Tag Heuer Watches
Watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
Jan 10, 2009 | Rado Diastar Anatom Jubile watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Pulsar Mens Wrist Watch
I have a similar solar modle Ive had since 1995 , about 4 years ago it started loosing time and the second hand started double ticking. I sat it down out side on a cool summer day for the hole day in the bright sun and never have had a problem since. knock on wood! It was also runover by a car last year and still works good. I wont ever get ride of it. Hopefully this helps u guys out
Jan 30, 2007 | Pulsar PXF216 Wrist Watch
Watches Logo
21 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
