Question about Cameras
I have a Boots Tripod (3UEB)the shims on one of the upper legs are missing. Can I buy replacement shims, if so where?
Make your own with a hacksaw blade. Just break off 2 pieces of blade and drop them in. Works a treat.
Posted on Feb 25, 2010
Legs Locks Loose
Ross
-It is possible that you are overloading the tripod, thus causing this problem (check specs on tripod model)
HOWEVER IF YOU AREN'T....Giotto uses (2) different leg lock designs..., quick release (normally adjusted by a socket wrench) or rotary (screw locks)!
- If tripod uses screw locks, sometimes foreign material gets into the mechanism and either damages it or prohibits from tightening!!!!!
Note: rotary locks are easy to maintain & if you need parts..., they are user replaceable and usually inexpensive! (contact Giottos distributor in the country you live in)!!!
BUT FIRST!!!! (often problem is caused by dirty lock mechanism)
-carefully unscrew the leg lock (that is slipping) until it separates from the leg higher leg section & carefully pull out the lower tube (at the top of the lower tube will be 'shims' that are part of the lock mechanism).
-Look closely at existing 'shims' do they show signs of cracking, of a build up of dirt, etc. (if damaged they will need to be replaced)
-if shims are undamaged..., use rubbing alcohol & a clean cloth to clean shims and both the tube they sit on and the inside of the tube they slide into.
-once both sides of the tubes and both male & female threads of the locking mechanism are cleaned..., place a light coating of a light oil into the threads (sewing machine oil, bike chain oil, etc)...., do not get oil on the shims!!!!!
-replace locking shims back into position and carefully slide leg tube back into place..., then screw locking collar on (this should not take any force..., if while threading lock collar back on..., it seems tight..., back off collar and check positioning of shims). Repeat procedure!!!
TEST RESULTS!!!
Note: in most cases with rotary locks, problem is purely a maintenance issue, cleaning usually fixes the issue!!!
Peter
Nov 08, 2013 | Giottos (BL1150) Tripod
The lower leg would not lock and comes off.
The grey part might be a shim that fits up into the leg lock in order for it to fit more securely. Ambico is no longer in business, and parts are not available so you might have to replace the tripod if you can't fix it yourself. You find tripods here: www.itripod.com
Feb 22, 2013 | Ambico Photography
I have reflector telescope 672 power and im missing some pieces. I need to get one tripod leg, all the screws to the telescope and the finderscope. I needed to find out how to go about getting these...
It's not worth hunting down that many parts for that small telescope. You cannot just buy a tripod leg-- you must buy the entire tripod. Eyepieces cost at least $30 each-- and a finderscope at least another $30-$40.
Locate another complete telescope. It's not economical to repair that low cost small scope. Toys R Us who sell that brand do not furnish replacement parts.
Dec 12, 2010 | Edu-Science (10166) Telescope
Missing Tripod parts
Without knowing the brand of tripod i cannot help. There are some brands of tripods that are made for the retailer and the name is licensed, so the name brand does not support or stock repair parts. Especially if the tripod is an inexpensive one. Because of the model and make of you tripod, I would recommend you throw it out and buy another one. In my opinion Slik and Manfrotto are two very good ones. Slik for the lesser expensive and Manfrotto for the more durable, expensive, parts are almost always available unless is it really old tripod. Find some Manfrotto tripods at: www.BogenTripodParts.com
Feb 12, 2010 | Photography
I have a nice manfrotto tripod and one of the snaps on one of the legs no longer works, so the tripod now slouches on one leg. Is it worthwhile to repair it, or do I just need to buy a new one? I paid...
If the leg lock is still there in one piece, should be no issue. If you notice, the leg lock covers bothe an upper part of the leg and a smaller diameter lower part. Take a socket (8mm if I remember corectly) and barley tighten the nits on the bottom half of the locfk. Loosen and tighten nuts until rasing and lowering leg is no issue.
Jan 10, 2010 | Photography
Is it possible to buy a replacement leg for a GB1140?
I would contact the factory and see if they have replacement part available. Try their website and ask. Most large retail manufactures have parts avaiable.
http://giottos.com/
Jul 06, 2008 | Giottos GB1140 Tripod
ART055 manfrotto pro tripod
Hey there fotoflika, I have had a similiar problem in the past and found replacement parts unavailable. My solution was to drill a small hole through the leg section, and I used a similiar size allen key to stick in the hole, effectively locking the leg in place. You could drill several holes for different extension lengths. Crude I admit, but cheaper than buying a new tripod.
Feb 04, 2008 | Manfrotto 055NAT3 Tripod
One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
May 26, 2007 | Velbon Ultra MAXi Tripod
Cameras Logo
214 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
