Question about Kodak EasyShare Z740 Digital Camera
On my M883 the photos are in the internal memory instead of the SD memory card and I cannot download them to the PC... Any solution?
    Genius:
  • Kodak Master
  • 1,099 Answers
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
  6. When you have finished copying pictures, reset the Image Storage location to your original setting.
Posted on Feb 05, 2010
  • 724 Answers
If you want to clear the internal memory after you copied the images to your card while you in the internal memory mode just delete all. than return to choose card memory mode
Posted on Mar 25, 2010
Internal memory running out despite internal SD card nearly empty.
You might try reformatting the SD card with a card reader connected to your PC. Also, your tablet has it's own memory limit, if you are saving stuff on the tablet memory instead of the external memory card you might be pushing into the tablet's limits. Get a handle of your memory limits by downloading ES File Explorer if you have an Android tablet to navigate internal and external memory.
Sep 29, 2015 | Tablets & eReaders
Camera will not allow me to "copy" photos to transfer from internal memory to SD card?
You may be able to connect the camera to a computer and access the picture files that way. Also make sure the SD card isn't close to full.
Jan 01, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
I need to transfer internal memory photos onto memory card
First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
Apr 28, 2011 | Fuji FinePix A850 Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
HI, i have a sony HDR-CX150 camera,a nd while ona trip last month i accidently deleted all my pictures and videos, all stored within my internal memory. is there anyway i can recover my files?
You can take the memory card out from Sony Camera, and then connect the memory card to computer with a card reader, you can then download a data recovery software to scan the memory card and recover lost photo and video files
Photo Video Recovery Software
Dec 01, 2010 | Sony Handycam DCR-SR40 Camcorder
Hello, I have a samsung es55 camera and need to retrieve some pictures after they have been deleted. I have looked online and it seems this is possible through accessing the recycle bin, thought I can't...
I'm working on the premise that you've deleted the photos from your camera memory or memory card.
If you have and used them since, its unlikely that you'll be able to retrieve them, you could have already over written them.
Its unlikely that you've deleted to your recycle bin, thats on your PC, usually already on your desktop. Camera's normally delete for good.
However, check your pc recycle bin, just double click onto it, it should be on your desk top. Once open you can choose to restore deleted files.
There are 2 file recovery programmes available for free from "filehippo.com" called "recuva" and "PC Inspector File Recovery 4.0". Download and install either of these onto your pc and recover from you camera memory to your pc (just create a folder on you desktop".
Good luck.
Jun 15, 2010 | Samsung Digimax L830 Digital Camera
I have successfully downloaded photos from my Polaroid PDC 3077 from the memory card (Fuji 128mb SD)to "my pictures" on my computer. I have bought a new camera Canon PowerShot A480 and cannot download my...
Have you tried connecting the camera (with the memory card still inside it) to your PC? You should have a data cable that came with the camera, so instead of removing the card use your camera to download to the PC.
Mar 08, 2010 | Epson Stylus Photo R300 InkJet Printer
Wot is the memory card slot for
HI,
The memory slot is an expansion slot that you can put a camera card (SD card) into so you save all you photo's to that instead of the internal memory.
This is because your camera only has a limited amount of internal memory limiting you to the amount of pictures you can save on the camera.
Purchasing a memory (SD card) is certainly an advantage and they can be used in card readers, MP3 players and computers etc.
Regards.
Sep 14, 2009 | IT Works Cameras
Computer does not accept the samsaung phone
Ensure that your photos are on the memory card of the phone(not the internal memory). Take out memory card and put in sd adaptor. Slot this into sd card slot on your pc and open it up as a drive. You can then copy your photos onto your pc.
Jun 22, 2009 | Samsung SGH-G600 Cellular Phone
Internal memory to sd card
I don't know your camera; but... Before we assume anything about your camera we should check that SD card in another SD device that we know is working. your camera should default to the SD Card like most devices, which are able to use both simultaneously. It seems likely that something might have happened to the SD card if that is the only one you have tried in your camera. food for thought
Aug 28, 2007 | Kodak EasyShare CX7525 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
185 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
