Question about Nikon COOLPIX L4 Digital Camera
The Coolpix L4 forget its date-time settings, and there is no way to set them. menu -> set up (ok)-> date (ok)-> date (ok)-> ... the result is "Time Zone" setup screen not the date.
  • Nikon Master
  • 19,396 Answers
Hi.
Nikon cool pix settings are saved into an internal memory (20 MB EEPROM I think).
The internal memory is kept alive by an internal rechargeable battery, that is recharged from the main battery.
If you leave your Nikon overnight with no main battery, or batteries have drained, then the internal battery will also drain , resetting the clock (it may drain in 6 hours depending on the camera, normally takes 12 hrs.).
If the internal battery is resetting immediately, or after few minutes, then it must be replaced.
The camera must be disassembled completely to replace the battery located on motherboard.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
If the clock does not work at all, and resets immediately, even when the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, stating that you did not do any improper use of the camera, and getting the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
Regards.
Posted on Feb 05, 2010
Change the date and time
Good day!
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Mar 28, 2014 | Computers & Internet
Date stamp coolpix s9050
If you want a date stamp on photos go to Menu and turn on Date stamp after setting proper date under time and date setting under Menu. Rich
Mar 20, 2013 | Nikon Inc Nikon Coolpix S9050 - digital...
HOW TO SET TIME AND DATE ON SAMSUNG GT-S5233A
Try to do this for you to update the time of your Cellphone..
-Open the menu. Enter the menu by either pressing the soft buttons for menu, or usually pressing the "OK".
-Choose the option that says, "Settings" (it is mostly a gear like icon) or something that is closely related to that; it may also say "Phone Settings."
-Scroll down to the option "Phone Settings."
-Scroll down and select "Time and Date." Choosing this option will take you to the time setting page where you can change the clock settings.
-Change the clock settings by typing in the numbers, or by using the scroll keys to determine the correct time. When this is accomplished select the "OK" option by pushing the "OK" button or by the center key.
THAT's IT!!!
Please Don't forget to click on 4 thumbs up.. THANKS!!
Apr 08, 2011 | Samsung Star GT-S5233 Cell Phone
I have a red flashing clock icon on the led screen. Wj=hat is this
The camera is telling you that its internal clock is not set. Go into the setup menu, select "Date", and set the date and time.
Feb 02, 2011 | Nikon COOLPIX L4 Digital Camera
Okay theres a little red flashing clock on my camera what does that mean?
hi there, that indicator means that you haven`t set the time and date on the camera
you can easily troubleshot this by choosing MENU then set the date-time
hope this advice will help
Jan 06, 2011 | Nikon COOLPIX L4 Digital Camera
How can I delete all pictures on my coolpix L4 at the same time?
Answer specifc to this camera as follows: With camera on, push the > button to view saved pictures, when first picture appears in the frame, push "menu" and you will see a prompt to "delete", press "OK" and follow prompts to delete "ALL" pictures. The manual for this camera does NOT provide this info, it only deals with ability to delete one at a time.
Oct 08, 2009 | Nikon COOLPIX L4 Digital Camera
Setting the time
On my 6310 all in one printer ------> Hit "Setup" key (with the question mark next to it >> Select Tools (menu item 6) with OK button >> Date and Time (menu item 3) with OK button.
Then set the date and time using the keypad on the printer and the ok button. Either the arrow keys or the setup button move through the various menu options.
Nov 05, 2008 | HP Officejet 6310 All-In-One InkJet...
Nikon Coolpix L4 flash not working
This has happened to mine a couple of times. I cannot select flash, and the blur indicator is on most of the time.
Solution is to go into 'menu', select 'SET UP' then 'reset all'. My flash selection then works again.
Since one doesn't tend to set much up with a basic camera like this, resetting shouldn't cause any issues.
Hope this helps
Mar 31, 2008 | Nikon COOLPIX L4 Digital Camera
Help
Old reply, but that's exactly what it is. If you recently changed batteries, the camera reset itself, and now you have to change the date, time, and timezone for where you are.
Nov 09, 2007 | Nikon COOLPIX L4 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
67 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
