Question about Quantum DLT-V4 DLT Tape Drive
Dlt-v4, the drive accepts the tape only to spit it out
Dlt-v4, the drive accepts the tape only to spit it back out again a minute or two later, during this it doesnt pick up the tape aswel what can i do to fix this
    Problem Solver:
  • 6 Answers
You have to try the other tape if the same problem you have to replace the head.
Posted on Mar 21, 2010
Tapes on dlt v4 tape drive shows write protected even though they are not
Hi Amit, Several things might cause this.
Hardware wise, the write protect switch may be broken in the tape drive. (two finger switches / levers to the side of the cartridge)
This is likely if you have just manually ejected a tape with a screw driver (not recommended).
However there are also software issues that could cause this. For instance Backup Exec could have been asked to prevent overwrite for 12 months. This is totally software based and is NOT dependent on the WP switch.
My top guess is that the drive will need repair though as this can be a common fault.
Tape Drive Repair UK Based We repair all makes models and formats
Mar 18, 2014 | Dell Computers & Internet
We are having an issue with our backups. The system event log says there is an error 7 and lists the tape drive as having a bad block. However the quantum diagnostic tool shows the drive to be healthy. ...
Event ID-7 is a "Bad Block" on the Tape being using. By design, when a Bad Block is encounter, the Tape Drive "Seizes the Tape" and goes offline. It can sometimes be difficult to get the Tape Drive to release the Tape. Refer to the Users Manual for instrcutions on how to Reset the Tape Drive. Sometimes applying the Firmware Update willl reset the Tape Drive and Eject the Tape.
Do not assume the Tape is Bad, but do not re-use until tested. The Tape may be Bad, the Tape Drive may simply need Cleaning or the Tape Drive may be Worn or Damaged. If you are using 3rd Party Backup Software, such as Backup Exec or Yosemite, you wan want to check the Removable Storage Servcie to see if it is set to Manual or Automatic. Any Tape Devices would need to be first Deleted in the Library Section of Removable Storage, then Sop and Disable Removable Storage. Since Removable Storage is in effect NTBACKUP, this Service can interfere with the Operation of your Backup Software and generate "Bad Block" Errors.
To Test the Tape with your Quantum Tape Drive, use a tool called XTALK ( xTalk-6.4.1.1_Quantum_Setup.exe ) that is found on Quantums Website http://www.quantum.com/ServiceandSupport/Index.aspx
You may run a write_read_full Test on the Tape. Be sure to Clean the Tape Drive first. If it fails the Tape, try it with a 2nd Tape, If it fails again, suspect the Tape Drive.
OldCountry73436
Oct 04, 2010 | Quantum DLT-V4 DLT Tape Drive
Superloader3 , don't recognize real capacity of tape
this may be a limitation on your motherboard. please check if your motherboard supports this much capacity. If you have another pc or laptop that is about a year or two, check if they would recognize the the capacity of the drive correctly. if not you may want check with quantum about their drives.
Jun 19, 2010 | Quantum DLT-V4 DLT Tape Drive
How do I remove a stuck tape?
Power the unit down and very carefully unscrew the cover.  The greatest care must be when taking the tape out so that you don't bend the unit.
Consider blowing it out to get rid of dust and it very likely has a problem that will require service.  My quantum px502 had a stuck tape and I took the cover off but the picker was already off track - $700 to fix that and replace a sensor.
It gets heavy use and was serviced before in the three years it has been running.
Jan 18, 2010 | Quantum DLT-V4 DLT Tape Drive
Not backing up
Run Quantum's DLT from the following link:
http://www.quantum.com/ServiceandSupport/SoftwareandDocumentationDownloads/Sage/Index.aspx
Understand that a bad tape will produce failed tests, so try to use a "known good" tape.
Regardless of the Pass/Fail results, the LogPages are as important, as they capture past failures and may point to the real problem.
Dec 08, 2009 | Quantum DLT-V4 DLT Tape Drive
What is a leader tape look like and how do I finf
The tape leader is a band of flexible plastic with a hook on the end that is attached to the reel inside the drive.
When a damaged tape is used in the drive or when the drive is faulty, the tape leader can miss hook the leader and it pulls through and just flaps around on the internal spool leaving the drive unable to accept any tapes and failing self test.
Re-thread the lape leader round the guides and past the head and hook the square hole in the leader back onto the plastic hook just in front of where the tape usually sits and power on the drive and see if it passes self test.
Although this is often just a damaged tape that causes this it can also suggest a faulty drive so dont use any important tapes in the unit till you are sure the drive isnt totally 100%
I have used www.tape-drive-repair.com who are pretty good for this kind of thing and not too expensive - if you need to send the drive away for repair / exchange
Jul 29, 2009 | Quantum DLT 4000 DLT Tape Drive
During extracting files from DLT tape to the local disc it gives input/output errors
Go to driver dectective and check to make sure your drivers are up to date.
May 20, 2009 | Quantum SDLT 320 External LVD...
DLT V4 Driver
Most tape drivers are loaded from withing the backup software. Symantec and CA work like this. I'd start there.
If not you have to start the remote storage service and check in device manager to see what it defaults to and see if will find the device for you.
Chuck
www.SanDiegoFixMyPC.com
May 06, 2008 | Seagate Travan (stt220000a-sst) Travan...
Quantum DLT-V4 DLT Tape Drive Logo
526 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
