Can i hook more than 1 digital audio piece of equipment? to onkyo tx-ds838
  • ohanlon2 Feb 05, 2010
    so if i have my cable box hook with a toslink and dvd with coaxe due i have to turn off the cable bos each time i use the dvd?
  • ohanlon2 Feb 08, 2010
    i tried hooking up the coax and the optical they cancel each other out i also tried high quality RCA splitter it doec work with optical signal but i found a solution i brought a digital video switch and i'm just useing the audio connections!
    thanks for the help!
    Brigadier General:
  • 8,546 Answers
Unfortunately, my copy of the manual is an optical scan so I can't actually read the legends very well for the rear panel connections or the OSD's...
Yes, use the Coaxial Digital Input, the Optical Digital Input and the AC3-RF (upper right). That's three (* or more).
I don't get what they're saying in the note on Page 13 about the three digital connectors and leaving the analog cables attached vis-a-vis multiroom and headphone use.
Page 29 discusses selecting the digital INPUT MODE. I imagine you could have three devices connected digitally and select between them using this control, but the displayed function labels may not jibe with what they really are.
* Few people seem to be aware that coaxial digital inputs or outputs can be physically shared because they're simply old -fashioned RCA cables. The only caveat is that you should only have power turned on for the input device you want to use or you'll get digital collisions. PLUS, you can join cables to make longer ones. Get some RCA splitters and you can run a couple of digital devices to any single Coaxial Digital Input (Upper right rear). I run mine this way.
Posted on Feb 05, 2010
  • David Dunn
    David Dunn Feb 05, 2010
    No, only if you use my trick of doubling a coaxial source onto one coax input. Internally, the receiver keeps each of its own connectors logically separate. Toslink and coax can't share the same port anyway.
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
Betreffende receiver TX-DS838, heb melding in uitleesvenster PROTECT
Dit betekent dat de versterker een fout heeft opgemerkt.
een aantal oorzaken zijn als volgt:
- een te hoge temperatuur, dit zou na een half uur afkoelen zijn verholpen.
- interne software fout, deze zou na 5 min zonder spanning verholpen zijn.
- een kortsluiting in (een van) de luidsprekers, alle luidsprekers loskoppelen kan zekerheid bieden.
- een defecte stuur of eind trap.
helaas is in de praktijk het laatste de meest voorkomende oorzaak en dient de versterker te worden gerepareerd.
Dec 26, 2010 | Onkyo TX-DS838 Receiver
Onkyo TX-DS838 Receiver. Mine just sparked smoked
Not worth repairing until the root cause of the failure is proven.
The reason being is that you can have it happen again if caused by any of the devices attached to it, such as inefficient speakers.
Jun 06, 2010 | Onkyo TX-DS838 Receiver
My onkyo tx-ds838 motor fan do not move
The fan in those Audio System only turns at about 1/4 to 1/3 of the ride of your volume control.
It had been intentionnaly designed like that, to achive a quiet operation at low hearing volume.
But if the fan don't move by cranking up the volume at 1/2 to 5/8 of the volume control (with speakers on). You need to have the fan or the fan power circuit checked by technician.
Spider Guy
Mar 15, 2010 | Onkyo TX-DS838 Receiver
Onkyo services manual
Go to http://www.retrevo.com/, regsiter for free and search for Onkyo TX-DS838. It will prompt you to download the manual (3.3MB).
Feb 02, 2009 | Onkyo TX-DS838 Receiver
Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Sep 02, 2008 | Onkyo TX-DS838 Receiver
Sound cutting in and out
Same problem here....took it to authorized onkyo repair and cost was $700+ for new board. Got the 707 from crutchfield instead.
Nov 09, 2007 | Onkyo TX-DS838 Receiver
133 people viewed this question
 Grubhead
Grubhead
