Trying to connect to the internet...using a clear wireless modem.....i need the wifi codes for either ZyXel_445, Toni or linksys_SES_27997 networks....
  • 4,889 Answers
Surething . I can get you the default password provided you haven't changed it. But I need the make and model of the modem/router you are trying to connect to.
Sai.
Posted on Feb 05, 2010
I am computer illiterate. Someone gave me this ZyXEL P600 series. How do I use this, and what does it do?
Hello, Roger -
The ZyXEL P600 appears to be a wireless computer modem / router (WiFi modem / router.)
To use it with a computer, you will need Internet service (a paid internet service provider.)
See the instructions here (Establishing a Wireless Network):
http://support.brighthouse.com/Article/Connect-Computer-Router-6628/
In case the person who gave you the wireless router did not give you the instruction manual for it, the manual you can find here, may prove helpful:
https://www.manualslib.com/manual/1054123/Zyxel-Communications-P-600-Series.html
Personal opinion: Seek out reliable relative or friend who is knowledgeable about computers and wireless routers to assist and instruct you. You will need one-on-one help.
Best wishes.
Mar 07, 2018 | Zyxel Computers & Internet
Hook up a zyxel p-663hn51 moderouterm to a linksys ae3500
How do I connect my zyxel p-663hn-51 modem to my Linksys ae3500 router for wireless service in my home
Jan 28, 2014 | Zyxel Computers & Internet
I have a ZyXEL EQ-660R-F1 and a Linksys Wireless Router (B BEFW1154) that I'm trying to hook up. Can you tell me what I need to do?
Who is your ISP (internet service provider)? Anyway, it is possible to get your set up working. ZyXel is the DSL modem gateway and Linksys, your router/wifi. If you are able to get online by hooking up directly to the Zyxel, then it is possible to add the Linksys to the system.
Dont hook up the Zyxel to the Internet port of Linksys just yet. First you have to configure the Linksys by connecting your PC to it with a cable. Boot up the PC.
Open web browser and enter the address 192.168.1.1 and hit enter. This is the default address of the Linksys. username = admin and no password. It is probably the same as the Zyxel which causes the conflict.
The first set up page may look something like this below.
Change the LAN IP address from 192.168.1.1 to 192.168.2.1
Then click apply...From now on the Linksys IP address is 192.168.2.1.
Now you can connect the Linksys internet port to the Zyxel. Reboot the Linksys and Zyxel.
Your PC should be on the internet after that. To check/setup wifi, you need to log back into the Linksys using the new adress x.x.2.1
Feb 15, 2013 | Zyxel Prestige 660R Router (91004397002)
ZyXEL P-330W wireless router
No it will not work you cannot connect a router to another router wirelessly and it will most likely not be detecting each other, routers are built to transmit internet signals from modems if you have a router and a computer but you do not have your own internet connection that will not work conencting to another router you will need USB Wifi Card transmitter/reciever to be able to connect to your friends wireless internet.
but if your friend only has a modem you can lend him your router and get a USB wifi transmitter/reciever to be able to connect to your router that is conencted to your friends modem this will work but will not work if you and you friend will both have a router creating a network.
Jun 20, 2010 | Zyxel Prestige P-330W Wireless Router...
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
SETTING WIRELESS
1. Shut off the power to your cable or dsl modem for about 30 minutes.
2. Connect the ethernet cable from your modem to the Internet port on the router.
3. After 30 minute power on ONLY the modem NOT the router
4. Wait about 60 seconds and power on the router
Try it now.
Oct 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Cable Network Routing with Zyxel 600
You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for 192.168.1.1 and I got a linksys wireless router and the ip address set for 192.168.9.1. Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
Aug 09, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
How do I connect a Linksys WVC54GCA camera to the router?
the camera and the router need to be on the same "subnet" if you don't understand the "subnet" please e-mail me at frcs68@hotmail.com.
the other things is that you can only use the camera "within your network". you can't see the camera from outside. like Starbucks, at work, or by use of any internet browser. etc.
I am assuming you want to able to see the camera using the web browser.
in order for you to see the camera from outside of your network, you have to enable a port on the router. (don't know if you have to enable a port on the Modem). which open your network for attack by outsider. In another words, anybody with wireless laptop can find your network and tap in to it and use it for what ever they want.
Oct 31, 2008 | Zyxel ZyAIR G-4100 Wireless Router...
Connecting using wireless
because of zyxel support only zyxel product only
Apr 03, 2008 | Zyxel Prestige 660R Router (91004397002)
Computers & Internet Logo
David Payne
David Payne
