Question about NetGear WGR614 Wireless Router
We transferred to a new home and a new dsl account. I've reset my netgear wgr614v5 to its default settings and reconfigured it to access but now it only works for pc's that are wired into the ports. laptops with wireless lan can sense it but cannot connect. please help?
  • 136 Answers
You can try to delete the wireless connection and recreate it
When you reset the router all the security settings are erased
Create a new security setting on the router
Create a new wireless connection on the computer
This should work
Else change the SSID and scan the wireless network and try it
This should connect you
Posted on Feb 06, 2010
    Sergeant:
    Champion:
  • 265 Answers
When you reset the router the default setting for encryption is probably off. Hopefully you had encryption on in the old home - but now the wireless computers are still trying to connect using the key/encryption.
Posted on Feb 05, 2010
Can't get a link when trying to turn a Netgear router WGR614v8 into access point with a xfinity SMCD3GNV as the host router.
Log in to your NETGEAR router by browsing to
http://www.routerlogin.net/ or http://www.routerlogin.com./
Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults.
however, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection.
Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply.
If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
May 20, 2013 | NetGear WGR614 Wireless Router
I have a netgear router and im not connected
Log in to your NETGEAR router by browsing to http://www.routerlogin.net/ or http://www.routerlogin.com./ Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply. If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
Apr 09, 2013 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Default access
You didn't supply the Model of NetGear device. Push and hold the reset button for 30 seconds or so, release. This will reset to default settings. Reconfigure the SSID and Security settings. This will help: http://kb.netgear.com/app/answers/detail/a_id/119/~/configuring-your-netgear-router-for-cable-internet-connection
Dec 29, 2012 | NetGear Computers & Internet
Forgotten password and username to access router
If you forget the password, you need to reset the device to the factory default settings. In that case, all configuration settings of the device are lost then you need to reconfigure the router,
To reset the device to factory default settings, follow the instructions from this link,http://global.dlink.com.sg/site_support/DSL-2640B/Manual/DSL-2640B_manual_v2.pdf
11_20_2011_12_11_30_am.pngHope this helps.
Nov 07, 2011 | D-Link - DSL-2640B Wireless Broadband...
How do I connect Netgear router (WGR614v5) to Belkin modem (voip 4 port wired gateway)
  1. im not sure if this will help it worked with my thomsom modem &netgear router
  2. hope this helps good luck
  3. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  4. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Oct 22, 2010 | Computers & Internet
What if after you press the reset button, wait 30 seconds, disconnect DSL modem and disconnect router and restart everything (several times) and it still doesn't work. It was working fine before we...
When you reset the router, it comes back to factory default settings. Now you will need to reconfigure the router for the Internet connection.
If you have the CD then try to run the CD.
Or you can reconfigure the router without the CD also.
Click Here for step by step solution
Oct 14, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
D-Link 615 Default password not working.
Your default admin password should also be blank.
-Comp Doctor
Feb 01, 2010 | D-Link DIR-615 Wireless Router
Setting up NetGear WTG624v3
In order for your to access the router setup for this you need to check the IP address and default gateway of the computer that is wired to the router, the defaul gateway is the number that you need to type in to the address bar so you can reconfigure the router back, To check Ip and default gateway of your computer, Just click on the Windows logo and look for start search then after that type in CMD and hit enter then you will be on the command prompt there type in IPCONFIG hit enter and there look for IPV4 and look for the default gateway, the default gateway should start with a 192.168.x.x the default gateway is the number that you need to type to the address bar to be able to log in to the router.
Note if the IPV4 starts with a169.x.x.x you need to press and hold the reset button of the router for 15 seconds and check ip agaian if you already getting a 192.168.x.x...then continue accessing the router page...
Oct 16, 2008 | NetGear WGT624 Wireless Router
Problem in reconfiguring WGR614 v5 after reset
You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
Cheers !!
Feb 24, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
