Question about Coffee Makers & Espresso Machines
My Magimix M200 won't pull through hot water when making espresso?
EsWorld
  • 1618 Answers
SOURCE: cannot turn off flashing lights on buttons to start espresso
The keypad needs to be programed. Depending on your model there will be a small toggle switch on the right side, just behind the connection of the hot water valve(you will have to remove the top panel). Move the switch to the left, then press the program button at which time all the lights will be lit. Using a measuring cup press a button you want to program until you get the desired amount, then press the stop button(when programed the light will turn off), repeat to program the other 3 buttons. When done program move the toggle switch to the right. If the machine does not hold the program then the flowmeter under the drain tray(silver box with 3 wires on top), is damaged. Either repalce the top or check the impeller in the flowmeter, the magnets might dirty.(Make sure water is turned off before openning the flowmeter.
Posted on May 28, 2009
  • 145 Answers
SOURCE: KPES100PM Espresso Machine - will not make espresso
While I am familiar with Kitchenaid espresso makers, I am not familiar with this problem. I would suggest calling Kitchenaid Customer Service, as you will have options under your Pro Line warranty. Their toll-free telephone number is:
1.800.541.6390.
Posted on Aug 08, 2009
multilinkent
  • 739 Answers
SOURCE: Gaggia Syncrony Digital Water leaking out
HI.
did u mean water is leaking under the machine,
if it is usually because chamber is filling with coffee powder and water can not make it drain tray, you can replace the O-rings on a white plastic valve piston and gaskets to the unit that drink, and clean out the small chute drain tray from space.
Download Gevalia Product Manuals here
Also look at some of the troubleshooting process is often done..
LINK 1
LINK 2
Posted on Jul 17, 2011
EsWorld
  • 1618 Answers
SOURCE: I can get steam and hot water but the hot water
Descaled the machine using ScaleKleen or Pulybaby cleaner, here is an easy manual for descaling.
Posted on Aug 09, 2011
  • 115 Answers
SOURCE: new out of the box. won't dispence water to
Hi. Is your pump working. Should be able to hear it. If its making a really loud noise then it could be an air lock in the line. Try using the hot water button to bleed the system. Also see if it will despence water wiyhout any coffee in handle. Dazza REPAIRER
Posted on Sep 24, 2011
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
Won't pull water up into k cup, instead hot water flows back into the reservoir.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 13, 2011 | Keurig Platinum B70 Coffee Maker
Hi, i cannot get water to go through the machine through the coffee capsule. The machine makes the pump noises etc but no water comes through from the jug at the back. Any suggestions of what to do? We do...
You can download the instruction manual from various places online; the instructions for the automatic and manual versions are slightly different but you can find them here:
www.eirvik.is/gogn/L/m100.pdf
www.eirvik.is/gogn/L/m100_automatic.pdf
As a first step I would suggest checking that the water can get out of the tank (just touching it with your fingers (over a sink!) should let drips out). It not, try cleaning that. You could also try descaling it (as in the manual). By the way, if the machine is less than three years old and you still have proof of purchase the Nespresso club will honour the warranty and fix it free of charge; if not, give them a call anyway and see what you can get them to do for you.
Aug 22, 2011 | Magimix L'Expresso Espresso Machine
Magimix Essenza M100 - purchase last week Is there a way of selecting cup size to adjust volume of water delivered? or Do I have to manually switch off the water flow?
It depends if you have a manual or an automatic machine. If you're not sure, the manual one has just one green button, whereas the automatic has two. The automatic one delivers a fixed amount of water, which you can vary but following the instructions. If you have a manual one then you need to press the button once to start the flow, and again to turn it off.
Hope this helps. :o)
Aug 18, 2011 | Magimix L'Expresso Espresso Machine
Hot water tap no longer works. Cleaned out deposits and it still only drips out. What needs to be done. I fear the boiler is corroded or the tap is blocked with calcium despite the water filtering system....
Because the hot water spout is controlled by gravity, it is partially clogged, Here is a little story and see if this helps,Let me know
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Jun 23, 2011 | Bunn VLPF Coffee Maker
User manual for san remo coffee machine (Capri)
i have one. Can send it to you . I am from holland
Jul 19, 2010 | Coffee Makers & Espresso Machines
The steam wand keeps throwing out water and making my milk watery
Call the Nespresso Club, they will hepl to solve it in no time
0800 442 442
Good luck
Frog
Dec 28, 2008 | Nespresso D300 Espresso Machine
Coffee Makers & Espresso Machines Logo
187 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
