Question about Datamax I-4208 Thermal Label Printer
How to improve the resolution for Datamax I-4208? Can i change my printhead (KPA-104-8MTA4-DMX2 655) for other with more resolution??(I-4406, or A-4408) anyone knows if it works?
    Problem Solver:
  • 10 Answers
1. If your printhead doent have burn element no need to change and if your platen roller is uneven change it.
2. check the setting of your darkness both printer and the job data
3. check the quality of your ribbon and label if this is match. some cheap ribbon is poor on quality.
Posted on Apr 15, 2010
HOW TO FIND THE ip ADDRESS ON A DATAMAX i-4208
To view or set the IP Address on a Datamax I-4208, use the Front Control Panel on the printer and follow these steps:
Press Menu, go to Communications, then NIC Adapter, then IP Address.
Jun 19, 2014 | Datamax I-4208 Thermal Label Printer
Why datamax M class 4208 only prints on one side of the label?
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Apr 30, 2014 | Datamax I-4208 Thermal Label Printer
Only blank label prints out. Any reason? If it's the termal how do I do the clean? Any operator's guide? Thanks Gee
g_atsebha: If label is correct, then clean the printhead using alcohol isopropilic or maybe the printhead need adjust.
Roberto Martinez
padrino99@prodigy.net.mx
Aug 22, 2011 | Datamax DMX-I-4208 Label Printer
We have several Datamax I-4208 printers and a few of the older I-4206 models. It would appear the replacement printheads are one in the same for both models be we cannot get either of our spares to work in...
Some changes were made on the I Class units and the new printheads do not work correctly in the discontinued 4206 models. You need part number DPO20-2262-01 for your I-4206.
Jan 18, 2010 | Datamax DMX I-4206 Printer
Datamax i -4208 printer
Any Thermal Transfer or Direct Thermal label on a 3" i.d. roll with maximum o.d. of 8" and label width between 1" - 4". Thermal transfer labels require appropriate ribbon.
Nov 24, 2009 | Datamax I-4208 Thermal Label Printer
Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
4208 Datamax M Class printer Problems
Check inside the green guide (sensor) for pieces of label. That will block the sensor. If the sensor is reporting a thickness which is double (250) what you expect, then that is definitely the issue.
Jun 27, 2007 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 Thermal Label Printer Logo
296 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
