Question about Kodak EasyShare Z1275 Digital Camera
How to replace a cracked screen on a kodak Z1275 camera
  • 712 Answers
Http://www.clickondavid.com/LCD7430.pdf
This might help you. Its an illustrated method for Replacing an LCD Screen on a Kodak EasyShare CX7430. This may be applicable 4 your model also.
Posted on Feb 05, 2010
Testimonial: "thanks worked a treat new screen on and working also found vid on you tube "
    New Friend:
For a video of this process go to http://www.youtube.com/watch?v=krsTApJmJi0 too bad it's in German.
Posted on Feb 27, 2013
3 Suggested Answers
SOURCE: LCD screen replacement
Here's how to replace it:
Remove the various screws on the outside of the case, as well as those inside of the battery door. The front of the case will come off with very gentle prying. If not, look around for a screw you missed. You will now see a few screws holding the internal camera onto the back cover; remove. Now, it looks like the knob on top of the camera, having part of the case around it, will have to come off or be pulled off. This is not the case. Line the symbols on the knob up, so the video symbol points to the front of the camera. The knob lines up interally & then the case slides off, again prying gently. Now the back is off. The old screen is held in by clips around the screen & on mine there was adhesive holding it in. Pry the screen gently away from the camera. The ribbon cable folds over behind the screen & is inserted into a slot. It will pull right out. Note which way the contacts face. Now, take the new screen & insert the end on the ribbon cable into the slot the same way the old one was. There will be some resistance so use the utmost gentleness when inserting the cable, as kinking the ribbon cable will likely break it & you'll have to chuck the whole thing & order a new one. On my replacement, there were 2 tiny little tabs, on each side of the connector, which I was able to press down on. Now, carefully bend the ribbon cable under the screen the way the old one was & press into the clips. You can now put the back & front covers back on. Note some screws go through both the back & front covers. I stressed throughout this note using extreme finesse, not brute force, in fixing your camera, which will ensure you won't screw up it up.
Posted on Sep 17, 2009
  • 11967 Answers
SOURCE: lcd screen cracked on kodak Z1485 camera
Google the words...disassemble a digital camera.
Posted on Sep 05, 2009
I have kodak easy share z1275 camera, whenever i try to take a click of photo the screen shows friction or some thing like shaky images gets clicks, means the photo which gets clicked shows all blur...
Check your camera settings may be its on Night mode .Make sure you using the Auto ,Landscape ,Portrait etc..NIght mode can use with the help of Tripod.
Sep 27, 2010 | Kodak EasyShare Z1275 Digital Camera
Z1275 view screen partial closed upper left corner shows a small area I
In order to answer your quarry.
Please explain exactly what you see on the LCD and what effect it has on the use of the camera.
Dec 09, 2009 | Kodak EasyShare Z1275 Digital Camera
Z1275 produces horizontal lines through images. Flash, auto, program....doesn't matter what mode.
Hi
If your Z1275 has horizontal lines going through the images you should call Kodak Technical service
the number is 18002356325 op1 op12 op2
thanks
hope this help
Byron
Sep 16, 2009 | Kodak EasyShare Z1275 Digital Camera
DIGITAL CAMERA SCREEN FOR KODAK Z1275
I DONT KNOW IF KODAK IS THE SAME WORLDWIDE BUT I GOT MY SCREEN DIRECTLY FROM KODAK FOR 30 DOLLARS. TRY KODAK SUPPORT ONLINE.
Aug 11, 2008 | Kodak EasyShare Z1275 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
348 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
