Question about Canon ImageRUNNER 330s Copier
Canon imagerunner 330S
When i go to print test page I get 30 pages of garble(dos).
This started after we installed a new hard drive in computer?
I know the ip address of the printer but i am not sure how to set up computer?
HELP
thxs in advance
Did you need to connect the machine for printing? Sounds like you have installed an incorrect driver. You can go to canonusa.com and find the correct driver. Make sure you specify for the correct machine.
Posted on Feb 20, 2008
  • Nate Leon Feb 20, 2008
    Or if you have the disc that came with the machine, that would be better.
What does a hard drive cost for a cannon 330s
A new hard drive is about $100.00..... The problem is getting some one to flash the drive with the correct software. The copier is about ten years old or soo.
Jan 13, 2013 | Canon ImageRUNNER 330s Copier
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 5020 Copier not printing parallel attached
open your cd and try PrinterDriver Installer from misc folder
Apr 06, 2010 | Canon imageRUNNER 5020 Copier
Have a print job in the printer that i want to cancel. have unplugged the machine from the network, unplugged the machine from power. when i turn power back on, it start printing 500 page job that i do not...
Press the [PRINT MONITOR] key in the lower right corner of display. If fascimile option is also installed, it would say [SYSTEM MONITOR] key in same location. Anyways, after in print monitor screen, select the job that you want to cancel and press [CANCEL] key. Press [YES] to cancel. Press [DONE]. You might want to pull out all of the paper trays so the machine can't print while cancelling documents. Let me know.
Nov 02, 2009 | Canon ImageRUNNER 330s Copier
IR 1023 iF goed on - doen not print
re-installed the driver after deleting as administrator - power user does not seem to allow certian vista installations.deletions - geez
Jan 26, 2009 | Canon imageRUNNER 1023iF Black and White...
Networking imagerunner 2200
First, plug the printer into the network with an Ethernet cable. Then, go into the configuration page on the printer's display and print a configuration page. Look for the IP address. When you have that, go to the computers that need to connect to the printer. (Note that this tutorial is for Windows XP, I am not familiar with Vista but this should give you a basic overview.) Go to Start > Printers and Faxes. Click add a printer on the left hand side of the window. Select a Local printer attached to this computer, and unselect automatically detect. On the next page, click create a new port > TCP/IP port. Type in the IP address of the printer. Then choose the driver you are going to use, you should be able to find the IR 2200 driver under canon pretty easily. If not, go to canon.com and download their drivers. Once you do this, print a test page and it should print. You are then fully configured.
Please rate, Thanks!
Jan 21, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Print is garbled with PJL commands
unplug printer then plug in again and reboot computer
May 24, 2008 | HP LaserJet 5p Printer
109 people viewed this question
old marine
old marine
