Question about Lexmark X646e All-In-One Laser Printer
We get the printout of the logs when we scan the document. if i disable the print log option, is there any other way to get the logs of scanning done?
Ajkill
  • 2035 Answers
SOURCE: scanner not workin-lexmark x1240
Which operating are you using if your using (Vista use windows photo gallery to scan)
Posted on May 02, 2008
IB4G2008
  • 3587 Answers
SOURCE: lexmark X4270 doesn't want to scan
sounds like your scan settings need a look..do you have the print manager installed?
Posted on May 03, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Posted on Oct 20, 2008
rhoncruz
  • 134 Answers
SOURCE: lexmark x2500 err msg: UNABLE TO CONNECT
What you will see
When trying to print, you get a communication error; the device is correctly detected in the Device Manager, the firewall is not blocking any files and you can scan using the All-In-One Printer.
Explanation
Any PC using the AMD USB architecture is preventing the printer from printing when connecting via USB.
What to do
Follow the specific steps for the PC manufaturer below:
Dell Studio 1536:
IMPORTANT: Do not replace any hardware, before performing the following steps:
Step Action 1 Go to Control Panel 2 Go to Programs and Features 3 Uninstall AMD USB Audio Driver Filter
Note: Uninstalling this USB audio driver doesn't cause any impact for systems with Vista Service Pack 1 installed
Acer Aspire 5530, Extensa 4130, Extensa 4430, and TravelMate 4530:
There are files available to address printing problems when connected to a USB printer or multi-function printer, for Windows Vista and Windows XP.
  • Printer did not print, print jobs will be listed with the status "error" in the task list
  • No error message appears, printer simply does not print
  • Problem only manifests when the printer is connected via USB
Please go to the Drivers and Downloads area to get the file appropriate for your operating system and unit.
US Customers:
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_Vista_Setup.msi
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_XP_Setup.exe
EMEA Customers:
ftp://ftp.work.acer-euro.com/notebook/aspire_5530/vista/Drivers/USBFilter107_Vista.zip
IMPORTANT: The third-party products discussed in this article are manufactured by companies that are independent of Lexmark. Lexmark makes no warranty, implied or otherwise, regarding the performance or reliability of these products.
Still need help?
If you need additional assistance, please contact Lexmark Technical Support. NOTE: When calling for support, you will need your printer model/machine type and serial number.
Please call from near the printer and computer in case the technician on the phone asks you to perform a task involving these devices.
I hope it helps!!!
Posted on Dec 02, 2008
dan231
  • 236 Answers
SOURCE: Scanning as PDF
I see from Lexmark's site that your printer can scan to PDF Using the Productivity Suite buttons. The manual is here
But if that doesn't work for you...
I use PDF Creator.
It is a windows program that installs a printer driver that allows you to select it as a printer from any program and will create a PDF file.
For example, you can scan as an image, then open that image in an image viewer then print it to PDF.
Posted on Dec 08, 2008
Fax and print buttons dont work konica minolta 7235
FAX is option do you have the FAX kit installed???, Scan is normally a kit also on that legacy Konica machine. if you have the IP address to the machine place it in your url box, if the machine is networked you should see the copier own web page
Mar 19, 2017 | Konica Minolta Office Equipment & Supplies
My Dell Inspiron freezes up when I open up an application. What could be the problem?
Most likely overheating. The Cpu is running fine with no load, but when asked to load a program, it starts working harder and gets hot. It sounds like a good heat exchanger and fan cleaning is in order.
If this information was helpful, please rate it high. thanks.
May 07, 2011 | Dell Inspiron 1525 Notebook
Error loading winyvf32.rom
http://www.superantispyware.com
Please run ATF and SAS:
Note.. SAS doesn't open the registry hives for other user accounts on the system, so scans should be done from each user account.
Note 2: On Vista, "Windows Temp" is disabled. To empty "Windows Temp" ATF-Cleaner must be "Run as an Administrator".
From your regular user account.. Download Attribune's ATF Cleaner and then SUPERAntiSpyware, Free Home Edition
Save both to desktop .. DO NOT run yet. Open SUPER from icon and install and Update it Under Scanner Options make sure the following are checked (leave all others unchecked): Close browsers before scanning. Scan for tracking cookies. Terminate memory threats before quarantining. Click the "Close" button to leave the control center screen and exit the program. DO NOT run yet.
Double-click ATF-Cleaner.exe to run the program. Under Main "Select Files to Delete" choose: Select All. Click the Empty Selected button.
If you use Firefox or Opera browser click that browser at the top and choose: Select All Click the Empty Selected button. If you would like to keep your saved passwords, please click No at the prompt. Click Exit on the Main menu to close the program.
NOW Scan with SUPER Open from the desktop icon or the program Files list On the left, make sure you check C:\Fixed Drive. Perform a Complete scan. After scan,Verify they are all checked. Click OK on the summary screen to quarantine all found items. If asked if you want to reboot, click "Yes" and reboot normally.
To retrieve the removal information after reboot, launch SUPERAntispyware again. Click Preferences, then click the Statistics/Logs tab. Under Scanner Logs, double-click SUPERAntiSpyware Scan Log. If there are several logs, click the current dated log and press View log. A text file will open in your default text editor. Please copy and paste the Scan Log results in your next reply. Click Close to exit the program
IF THIS WORKS then create restore THEN do following steps
• Go to Start > Run and type: Cleanmgr
• Click "Ok"
• Disk Cleanup will scan your files for several minutes, then open.
• Click the "More Options" Tab.
• Click the "Clean up" button under System Restore.
• Click Ok. You will be prompted with "Are you sure you want to delete all but the most recent restore point?"
• Click Yes, then click Ok.
• Click Yes again when prompted with "Are you sure you want to perform these actions?"
• Disk Cleanup will remove the files and close automatically
Dec 11, 2010 | Microsoft Windows Vista Home Premium...
Does the C6100 have fax history printout capablity?
Hi
Yes, Photosmart C6100 series does have the capability to print the fax history i.e. known as fax log, but its is only possible if you have not performed any resets recentlyt
How to print that?
Please follow the following steps to print it
1. Press the setup button on the printer
2. Go to the option that says 'Print Report'
3. Press Ok on print report
4. Scroll down using the arrow keys and go to fax log
5. Press Ok on fax log
6. This would print the history
All the best!!
Oct 29, 2010 | HP Photosmart C6100 All-In-One Printer
How to print fax log
try this
* Press Setup menu (setup button) on the printer.
* Go to the second option print Report.
* Select the 6th option Fax log. Press Ok.
* The fax log will print now.
Apr 16, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Hp 1300 series will not print word document but prints excell documents and notifications from e-mails etc
Your issue is with the Office package or your PC is virus effected, Not with the printer. Follow the steps
  1. Create a new user in the PC(Start-control panel-User accounts-New)
  2. Log off and Log in to newly created account
  3. Now try printing from Word application
  4. If you cant print yet, Try download AVG Free version anti virus and scan fer viruses.
Dec 03, 2009 | HP LaserJet 1300 Printer
Please guide me the steps to disable the" print the event log"
If you don't want see a printer notification event in the event log you can disable that..
Start regedit and find the key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers".
Add "Eventlog" and set the value "Reg_DWORD" at "0".
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Jun 25, 2009 | HP LaserJet 1020 Printer
Please guide me the steps to disable the"print the event log"
You will need to edit the registry to do this.
Jun 24, 2009 | HP LaserJet 1020 Printer
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Problem with Onenote 2OO7. Inserting a file as a printout.
Inserting a pdf file into a file won't work because Microsoft files can only read them as an attachment.  There were some licensing squabbles between Microsoft and Adobe which caused this to happen.  You can do it if you can scan them as a tiff file.
Sep 17, 2008 | Microsoft OneNote for PC
Lexmark X646e All-In-One Laser Printer Logo
114 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
