Question about Sony DAV-FR10W System
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it. My remote says 'progressive' on the top left and has a little button next to it, but it looks nothing like the remote in the manual. Right now i get a double screen black and white picture because it's set up under the 'component video/progressive' setting but i want to use the 'svideo/interlace' or just the regular yellow video cable to watch dvds.
  • 10,594 Answers
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Posted on Feb 05, 2010
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
Hello. I switch an option, i switch to progressiv option and i dont see anithing how can i reset the DVD player? It is a piooner DV-300-K DVD player. Thanks for help.
According to the Pioneer FAQ for this item :
"You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on."
Mar 03, 2011 | Pioneer DV-300-K Player
I am stuck in the Progressive Scan Mode on my DVD player & cant get it out of the blue screen. I have tried reseting it & even unplugging the player.
If your TV does not support progressive scan, you won't be able to get out of the blue screen. The only way to solve this issue is to connect the unit to a multistandard TV which has this capability, then in the player's on screen menu, look for anything that would allow you to select either progressive or interlace as its video output (or has progressive on and off feature) - and switch progressive 'off'. This should revert the output back to interlace. Then unplug the combo, reconnect it to your original set, and it should work fine after that.
Not impossible to correct, but a real pain if progressive is selected in a DVD player's output and the TV does not have that feature. Some DVD players have progressive output as a default option in their setup. Reverting it to interlace or turning it off so it matches the TV it is connected to should solve this problem.
Feb 16, 2011 | Goldstar GBV241 DVD Player/VCR
I changed some video imput and now i cant see anything, only audio
1. Press FUNCTION repetedly until "DVD" appears in the front panel display.
2. While holding down rewind botton, press FUNCTION.
The output signal is changed to interlace format.
Apr 23, 2009 | Sony DAV-FR10W System
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
How do you know if you have a Progressive Scan TV? We are having problems playing DVD's from video stores. It will play the previews, but when it gets to play the movie, it doesn't play. I can play them...
Well, a progressive scan TV displays in the same resolution as a normal interlace TV. It's very hard to tell the difference in all respect.
Progressive rewrites every single line/pixel on the screen. Interlaced simply skips a line and rewrites half of the lines every frame. So, progressive can show higher quality, but interlaced was more predominant as it was easier to create for TV makers in the earlier days.
Most of today's better televisions are strictly progressive and you won't have any problems.
I'd try a different DVD player with the selected titles and see if the problem persists. It could be the TV or the or the player itself. If the titles work in another DVD player. Try a newer television and see if it works there.
Hope these ideas help.
Sep 21, 2008 | Televison & Video
Stuck in progressive scan mode.
Based on your description, it seems that you set the DVD to progressive scan output, but have it hooked up to a TV (CRT) that cannot accept this signal. Because the TV can't accept the signal, you can't view the DVD menu to change the setting back to interlaced.
On the back panel you have "Component Video Out" for output via component cables, but there is also a yellow RCA connection labeled "Video Out". This is a "composite video" connection which does not support progressive scan. Try disconnecting the component cables and connect the composite video to a TV. The DVD will likely (hopefully) send a compatible signal (480i) through this connection, which will give you access to the menu.
May 12, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Sudden split screen
Your dvd player is in progressive mode, and your tv isnt capable of playing progressive mode.  To fix this, look on your remote for a button called "Progressive", and press it.  If you dont have a button like that, then look through your service manual for anything that says progressive mode, and it should give instructions on how to set it back to interlace mode.  This is a very common problem I come across when servicing DVD players, as inadvertently pressing the wrong button the remote will cause this.
Sep 07, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
Sony DAV-FR10W System Logo
158 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
