I have a TI-89 Titanium. It was in my backpack during a rainstorm Tuesday. I took it out tonight and it did not respond at all. The calculator will not even turn on. I bought it within the past year so it is fairly new.
    President:
  • 1,871 Answers
Hello :
Just read the both websites here and you'll be able to solve the problem : http://www.ehow.com/how_5544974_detect-computer-water-damage.html and http://www.ehow.com/how_5004042_fix-laptop-water-damage.html
for your calculator try this :
This works on most mini electronic devices like cellular phones and digital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
good luck .
Posted on Feb 05, 2010
The screen on my TI-89 Titanium turned blue after replacing batteries? How do I fix this? It turns on and off but does not respond to any other buttons.
If you cannot see anything on the screen, you may need to adjust the graphing TI 89 Titanium calculator contrast :
1.To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light.
Sep 01, 2012 | Texas Instruments TI-89 Calculator
Ti-89 titanium diagnostics
There is no DiagnosticsOn command in the TI 89 Titanium. The command exists on the TI83/84PLUS where it displays the r and r^2 coefficients. On the TI89 , the correlation coefficient and the determination coefficient (r, r^2) are displayed by default among the statistics if THE REGRESSION MODEL includes them. If they are not defined by the regression model they will not be displayed. In short, you do not have to turn diagnostics ON.
Apr 17, 2012 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
My TI-89 Titanium isn't turning on. I took it out of my backpack today and it wouldn't respond at all.
Try a hard reset, if you're willing to lose the contents of all RAM.
Press and hold the 2ND, Left-arrow, and Right-arrow keys.
Press and release the ON key.
Feb 05, 2010 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
TI-89
If you make a custom, you can have the Toolbar F function keys operate as 7, 8, & 9. If you respond with a rating I'd even write one out for you, and make it where you just hit [2nd] [CUSTOM] for the use of those keys.
Oct 03, 2008 | Texas Instruments TI-89 Calculator
My TI-89 Titanium Is Dead
You might have deleted something that the calculator uses to connect to the computer and run. If you can still connect, just download the software from the TI site and re-install it. If that does not work buy a new calculator, and plus a new one only costs 40- 50 dollars more than that repair.
Mar 16, 2008 | Texas Instruments TI-89 Calculator
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
