Question about Hyundai Televison & Video
I have a hyundai dvd pluss tuner. modal number hmicoin6 0509001321.I have lost the conecting cable on the back,ie tuner to dvd deck.can i prechace this as a spaer part?
  • danielboo732 Feb 05, 2010
    the cable is flat with 15 sets pins, its called a control cable
    President:
  • 2,923 Answers
The first thing that you need to do is to verify what kind of connection do you have for the Hyundai DVD Plus.
I tried searching for the cables but I'm not sure what to look for. But check the link below and see if that's compatible with your DVD:
http://www.xpcgear.com/usbdsc5.html
Good luck and have a great day!
Posted on Feb 05, 2010
How to conect red and white cables from tuner t4150 to pre amp p304 to eq 540 t0 cassette deck ta 2600 thank you
Normally your tuner is your preamp and then you go to the amp. Exception being is if it is just a tuner. That being said you should have a left and right in on your preamp that will accept your cassette deck, out from your cassette deck to the in on your tuner. out on your tuner to the in of the amp. Red is right and white is left on audio cables.
Jan 18, 2016 | Audio Players & Recorders
Run DVD through tuner
ok a bit confused, Tuner ? like amplifier or Tv Tuner ? regardless seems like a easy fix .
First your cable box as 3 cables:1st . Power cable to outlet
2nd. From the wall ( usually a Coaxial cable coming from outside box ) into cable box.3rd. HDMI or Second coaxial cable ( One of these usually goes to the back or side of your Tv depending where inputs are located.)
Now Dvd has 2 cables 1st to Power2nd. To TV ( Hdmi or Coaxial )
On the back of your Tv will have 2-3 HDMI inputs . Assign 1HDMI jack to each media your trying to use.In this case TV HDMI 1, HDMI 2 DVD.
Assigning HDMI's will now reflect on your TV menu selection. Choosing HDMi 1 or HDMI2 from Tv menu will allow you use or view desired Media option in this case DVD or TV.
Now if there is Amplifier / Tuner involved like to connect surround sound to, connection may be a bit trickier however same principal.Plug all media into HDMI 1, HDMI 2, respectively,this time to the back of the tuner NOT to back of TV.Once you have done that You will need a third HDMI cable now from the back of the Tuner ( output Jack, usually has lighter color markings indicating Output HDMI) to your HDMI 1 jack in the back of your TV. Now you have bridge TV/ Cable , DVD into Receiver / Tuner and Selecting media will now be done not through TV Menu as before but through Tuner / Receiver menu or selection.
Good luck .
Good Luck
Sep 20, 2012 | Panasonic DVD-A120 DVD Player
I HAVE A HM-5064A CD TURN RADIO DECK.WHICH I WAS TOLD THAT ITS A PHILPS.
no you need the appropiate code generator ,best advise is to go to the dealer .
Sep 22, 2017 | 2001 Hyundai Accent
Need to go to the dealer with your VIN number and proof of ownership if radio is factory installed. If aftermarket you need to contact the manufacturer.
How do i record from a vcr tape to a dvd on a sansui dual deck vcr dvd recorder?
If it is a combination VCR/DVD player,they usually can't do it.If you get a separate VCR player from a friend or neighbor,you can connect the VCR output to a cable box input,cable box output into DVD input,or if the DVD recorder has a digital tuner you can plug the VCR output player straight into the input of the DVD recorder.DVD recorders REQUIRE some form of digital input.That is why you need to route a VCR player through a cable box or the DVD recorder needs a digital tuner.If you are not sure if your recorder has a digital tuner,call sansui,they will know.I tried to find Sansui home and I found everything BUT DVD/VCR.If you have a manual it will be in there,or it may have a phone number on a label(back or bottom probably)of the unit.Good luck!Greg If you want to send me your model number,I will research it further too.It is up to you.
Aug 06, 2010 | Televison & Video
I have a Amp,CD player,Tuner,and DVD player. no a tape deck.how can i conect all, with out a tape deck through eqeualizer.
You can connect the EQ on the tape in/output of your amplifier. Tape out (or monitor out) to the input of the EQ and tape in to the output of the EQ.
Listen to the tuner and than switch to the tape input, the tuner input will be still active. But in the tape "mode" your EQ will be active too.
Regards,
Gerard
Jan 10, 2010 | Yamaha EQ-70 Home Equalizer
Pioneer cd tuner deck model xc-is21t missing lead
go to www.donberg.ie and search for ADE7039 CONNECTING LEAD , order code piac 173
Oct 05, 2008 | Audio Players & Recorders
Sound no picture on cable
sweetkiss, if it works through the dvd player and not on cable/satellite box then the tuner is bad, if you have any type of cable/satellite box try running A/V cables out of the box to video input on the back of the tv and switch the tv to that video input, ie; vid 1, vid 2 etc. (your using one of those inputs for the dvd) this will give you your picture back, you can of course also replace the tuner in the set, good luck, BMW Rider
Feb 10, 2008 | Sony KV-27V22 TV
Picture fuzzy on SONY KP-57WS510
Sounds like bad tuner ( it is soldered in ).
I will research part numbers when i get to work today....T.
Nov 01, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Ilo dvd player wont search high channels
At a guess the device will only find channels it can detect. So what is your connection antenna or cable If antenna then all TV is line of sight and directional If cable - only the channel's the cable co supply will come down the wire.
Sep 17, 2007 | iLO DVDRH04 DVD Recorder
Televison & Video Logo
14 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
