Question about Nokia HS-4W Consumer Headset
I cannot pair my headset with a phone, i forgot my password
    President:
  • 1,738 Answers
Bluetooth Passcode
The passcode is 0000 (Four Zeros)
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Posted on Feb 05, 2010
I forgot the password to enter into the phone
most blue tooth manufactures use a 4 digit factory pin pairing code they are as follows 0000,1234,9999,or 1111 i hope thiss helps
Feb 25, 2011 | VXI BlueParrot B150 Wireless Headset
I need the password for my bluetooth explorer 390
If you forgot your password, please try below instructions:
How to Pair Your Headset If it Has Been Previously Paired With Another Device:
1. Turn the headset off. Press and hold the call control button until the indicator turns red and then turns off.
2. Turn the headset on. Press and hold the call control button until the indicator light continues to flash red and blue. The headset is now in pairing mode.
3. Use the commands on your phone to locate your headset. For most phones, select Settings/Tools > Connections > Bluetooth > Search > 3xxPlantronics. See your phone's user guide for more information.
4. If prompted for the PiN code/passkey, enter 0000.
Pairing is successful when the indicator on your headset flashes blue. Your headset is now connected and ready to use.
NOTE This headset is equipped with Secure Simple Pairing (SSP). If your phone supports SSP, you will not have to follow step 4; you will instead see a message on your phone alerting you to a successful pairing.
Feb 18, 2011 | Audio Players & Recorders
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Cannot pair headset with phone
Morning
After i reset the headset, the passcode "0000" allowed the headset to pair with my phone.
Thanks for the info that was posted as it helped me solve my problem.
Aug 26, 2008 | Nokia HS-36W Wireless Headset
Bluetooth problems
most bluetooth default passwords are 0000
it should pair up.
Feb 12, 2008 | LG enV VX9900 Cellular Phone
Tried paring Motorola BT H700 to my phone when it has already been paired to another phone
With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect.
Jan 05, 2008 | Motorola Mobility H700 Wireless Headset
Password
Hi To Pair the Phone, while the headset is off, press and hold the Volume button until the headset indicator light shines steadily. Open the folding microphone while the light shines steadily. Set your phone to look for the headset by turning on the bluetoth and starting discovery mode. After your phone finds the device and you accept the pair with the headset enter the password 0000 The headset light should flash several times to indicate the pair. Whala you should be up and running. If you need more help re post or email me hartmansp@inbox.com This link will take you to a awesome tutorial with pictures if you need it:: http://www.motorola.com/mdirect/demos/headsets/index.html
May 07, 2007 | Motorola Mobility HS805 Consumer Headset
Nokia HS-4W Consumer Headset Logo
96 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
