Question about Lexmark P915 InkJet Photo Printer
My printer works on one computer but not on another, both has the same operating systems. Message: Computer does not communicate with printer.
old marine
  • 2005 Answers
SOURCE: All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
Posted on May 21, 2008
SOURCE: lexmark5495 printer
this might be due to invalid drivers
www.lexmark.com for the newest ones.
Try this link for more Printer Resources
Posted on Aug 19, 2008
  • 6 Answers
SOURCE: No communication between computer and printer?
I had the same problem with my X5410, installing on Windows Vista. After about 6 hours of working on it I got it resolved.
I uninstalled the Lexmark software from my computer. Start -All programs-Lexmark -uninstall.
I then turned on all components of Windows Firewall. Control Panel - Windows Firewall.
I then re-installed the Lexmark software from the CD.
Hope this works for you !!!
Dan
Posted on Jan 18, 2009
john_yap
  • 51 Answers
SOURCE: my Dell computer does not communicate with my printer
hi there,
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
have a great day.
you can check this link for complete info.
http://tinyurl.com/yddyuw6
Posted on Oct 01, 2009
techabhishek
  • 66 Answers
SOURCE: computer isn't communicating with my printer
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Posted on Mar 27, 2010
"Communication Not Available" message is displayed
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
I am using canon lbp 2900 in winxp every few printout it give communication error message while it connected to computer. i have to restart system for further printing
Windows XP is not the latest operating system, and has very limited support on the MIcrosoft website.
Is the Windows XP operating system updated to service pack 3?
I would recommend updating the operating system to windows 7 32 bit in order to solve this problem permanently. It has similar specifications as XP, but will be supported by Microsoft when having such printer problems.
You could, also, try to delete the printer and reinstall the xp drivers for it to see if that works for you, if you choose not to upgrade the operating system.
Good luck on this computer/printer repair.
Dec 25, 2010 | Canon LASER SHOT LBP-2900 Printer
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    "No communication with Computer" message.
    hi Margaret,
    have you considered reinstalling the drivers and applications for this Lexmark printer ?
    if you need the drivers (compatible with WINDOWS VISTA only operating system), go to this link
    http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X3330&focusedTab=DOWNLOADS#1
    hope this helps
    Nov 12, 2010 | Lexmark X3330 All-In-One InkJet Printer
    My printer and pc have stopped communicating. The message on my computer tells me to choose a printer. I click on the Lexmark and it says ready but there is no location and I can't click on anything else.
    What is the operating system of your computer? How is the printer connected to your computer, wireless or hardwired via the USB cable? Make sure the print spooler of your computer is enabled.
    Jul 05, 2010 | Lexmark X4690 Wireless InkJet Printer
    Won't communicate with my HP computer, light in the middle blinks
    Did you change anything with your computer? Operating system? Service Pack?
    If you have two Z65n's and they're both behaving in the same way, there's clearly something happening with the communications coming from the computer.
    Those printers have been around for quite awhile. I doubt there are many still in service.
    If you have changed something on the computer, you might want to try downloading the most recent driver for your configuration at www.lexmark.com.
    Feb 28, 2009 | Lexmark JetPrinter Z65n InkJet
    Printer cannot communicate with the computer
    Drivers, Software, lost C.D....come this way!
    If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
    Nov 19, 2008 | Lexmark X2350 All-In-One InkJet Printer
    Lexmark 1200 Series
    unplug your usb cable,uninstall printer then reinstall
    Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
    May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Lexmark P915 InkJet Photo Printer Logo
    183 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
