Question about Apple AirPort Express Base Station with 802.11n and AirTunes
3g internet + wifi Airport express + Vista = problem
I am using Vista and get internet connection to the computer through my iPhone via usb. I also have an airport express that has created a wifi network. I would like to stay connected to my 3g iPhone network and at the same time connect to the Airport express wifi network (to be able to stream music). The problem is that when connecting to the wifi network the internet connection drops. Somehow the two networks interfer with each other. On my mac the same setup works perfect. I have tried to change order of preference and moving the 3g to the top. Any suggestions? Thanks.
  • f_lindqvist Feb 05, 2010
    Just to clarify the setup: Internet is provided to Vista computer via iPhone (usb). However, the Airport express (AE) network is not supposed to be connected to the Internet. So there should not be any problems with multiple Inernet connections. I just want to access the AE network to be able to stream music. So what I am trying to do is to be connected to a local network (iPhone+usb) and a wireless (Airport Express) at the same time. It works perfect on my mac (Internet connection stays connected when I also connect to the Airport network), so there must be a solution for Vista as well.
    How can I tell the computer to stay connected to the Internet via local network (usb+iPhone) while accessing the wifi network (Airport) to be able to stream music?
    Thanks!
    President:
  • Apple Master
  • 2,923 Answers
The network connections that you're trying to setup. The two sources of the Internet will Interfere with each other. Microsoft Windows does not allow two different connections at the same time.
The iPhone serves as the modem and it's getting connection through your wireless provider. And you're trying to connect your Vista via the Airport Express and it will definitely interfere with each other. Because the 3G connection and your Airport Express have different sets of IP address.
You mentioned that on your Mac, the same setup works, right? There's a possibility that Mac has the ability to disable one connection when you try connecting with another network.
The only suggestion that I could give you is to get the IP range of your iPhone 3G and then set a static IP address of your Airport with the same range as the iPhone. I'm not sure if this will work but try it and see if they will communicate with each other.
Good luck and have a great day!
Posted on Feb 05, 2010
    President:
  • 1,902 Answers
I had the same problem, and I had to switch from Windows Vista, to either Windows XP or Windows 7. Clients of mine had the same issue and they also had to do the same thing.
What are the main power and battery differences between iPhone 4s and iphone 5S?
Both Apple products have a built-in rechargeable lithium-ion battery that can be charged via USB from a computer or power adapter.
The Apple iPhone 4S battery allows:
8 hours of talk time on 3G
200 hours of standby time
6 hours of internet use on 3G, 9 on wifi
The Apple iPhone 5s battery allows:
10 hours of talk time on 3G
250 hours of standby time
8 hours of internet use on 3G, 10 on LTE and 10 on wifi
Both provide 10 hours of video playback and 40 of audio.
Sep 11, 2013 | Apple iPhone 5S
I have gateway model SX 2110 G does it have wifi if so how do I connect to internet
This Gateway desktop does not have a wireless (WiFi) adapter.
You can check out the specs on this WEB site.
http://us.gateway.com/gw/en/US/content/model/DT.GDYAA.002
SETTING UP A BROADBAND CONNECTION
First you need to decide what type of broadband and Internet service you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A USB wireless adapter uses the same 3G mobile/cell phone network and can be separately or combine with your cell phone account. This type of Internet connection uses a wireless device shaped like an USB memory stick.
Note - Combined services generally offer discount pricing and may include a modem/wireless router.
If you use a wireless router with a DSL or Cable Internet service then your laptop/computer with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop.
If you use the wireless 3G wireless broadband service, then you can access the Internet anywhere where your ISP has 3G wireless coverage. You need to check the service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to check with the various Internet Service providers to see if they can offer and the cost of the various plans.
Note the download limits and the associated additional costs if you exceed the monthly download limits. Once you sign up with a Internet Service provider, their documentation will include setting up instructions and/or installation CD.
Apr 11, 2013 | Computers & Internet
Is there a way to get my Toshiba Satellite pro 440CDX to conncect to a ethernet cord and not dial up
SETTING UP A BROADBAND CONNECTION (non dial-up connection)
3. A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
If you use a wireless router with the DSL or Cable Internet service then your laptop with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop.
Dec 29, 2012 | Toshiba Satellite Pro 440CDX PC Notebook
Trying to play Pandora radio via iPhone 4G using Denon ASD-11R dock connected to Denon 790. Connected according to manual. Used to work when using iPhone 3G. Will not now work via dock or via USB...
I have the same problem. Used to work even on Iphone 4 and suddenly it just stopped working about 10 days ago. Very strange as i have not updated my iphone (I'm on Version 4.02). My Denon dock is ASD-3W (wifi) connected to Denon 3808CI.
Any info appreciated.
Dec 20, 2010 | Audio Players & Recorders
Not able to connect to internet via airport express
Have you checked your system preferences, network settings? You have to tell the mac to use airport or ethernet. It may be setup to use the hard wire and not airport. You should see a link to turn on airport in the upper right corner of your screen. I think you can turn airport on there.
Apr 03, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
When connected to Airport Express via USB, it will
Airport Express provides only a print server, not a networked usb hub so it can only print. I'm afraid you'll have to go back to wired for scanning.
Mar 06, 2009 | Canon PIXMA MP610 InkJet Printer
Internet on iphone 3g??
Simply go to Settings > Wifi. If Wifi is off, turn it on. You'll see a list of available networks when you're in a hotspot. You can also have iphone tell you when you're near hotspots by turning on "Ask to Join Networks." You won't be able to use the internet when you're not in a wifi hotspot.
Oct 28, 2008 | Apple iPhone 3G
Use iphone for internet on my dell xp laptop
you need special software and probably jailbreaking it
Aug 29, 2008 | Apple iPhone Smartphone
Wifi problem on iphone 2.0
Try performing a soft reset by pressing and holding down the power button and the home key at the same time.
Aug 06, 2008 | Apple iPhone Smartphone
Apple AirPort Express Base Station with 802.11n and AirTunes  Logo
409 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
