Question about Sony Ericsson K750i Cellular Phone
My k750 has got white lcd whenever i switched it on and keypad dont work as well
Hi my nokia 3110c...phone whenever...i switch the phone on...the keypad doesnt work..infact it just works a few seconds as the phone is loading..(enough time to unlock the keypad using the security code)...
Hi, when a keypad does not work on a phone, it is usually caused by dirt inside the keypad area of the phone,you can open the phone and clean up the keypad area.
Sometimes too, as the case may be Chips also can affect the keypad and allows the phone keypad not to function.
There is an IC chip inside that controls the function of the keypad.
You can fixed the IC chip inside the phone by replacing the damaged IC inside the phone.
When you replace the damaged IC .i assure soluton tothe problem.
Take care.
Oct 07, 2010 | Nokia 3110 Cellular Phone
MY SONYERICCSON K750 BECAME WHITE SCREEN WHILE IAM USING
the display cable just came out
try fixiing it if you have proper tools open the shield unscrew the case to see the display cable placed below the keypad you just need to press it
May 17, 2009 | Lands Phones
Keypad not working
Push it hard.......or check if:
-The number 8 stuck on its place,or remained pressing.
-Your housing is tight or loose.
Sep 25, 2008 | Sony Ericsson K750
Sonyk750
when you switch on your sony k750 a white color appear on screen an blinks and turn off..? if does, your phone software needs to be updated.
You can download your software through this link..
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/k750i?cc=ph&lc=en
Read the instruction before you download. after you install the software to your computer make sure that your phone battery is in full charge when updating your phone.
Sep 25, 2008 | Sony Ericsson K750i Cellular Phone
My k750 restarts when i insert a memory card
plzz.. chect ur card properly...it is ok or not..then insert onother card in it...
Aug 03, 2008 | Sony Ericsson K800i Cellular Phone
White screen
If replacement has been done twice then it is the problem of software. I would suggest u to contact the hardware vendor.
Oct 14, 2007 | Sony Ericsson K750
White flashing screen & red light permanent
this complaint is probably software complaint so flash your phone
Jun 29, 2007 | Sony Ericsson K750
SONY ERICSSON K750 K750i INTERNAL KEYBOARD KEYPAD
You need a T6 screwdriver, unscrew the screws under the battery and the front case of the phone pulls off
Jun 15, 2007 | Sony Ericsson K750
Sony Ericsson K750i Cellular Phone Logo
20 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
