Question about Sony MEX-BT5000 CD Player
I have a sony MEX-BT5000 and when i switch it on a message saying offset appears and i have no power to my rear left speaker, please help.
  • 518 Answers
Try changing the balance control, as offset to me would say the balance is one sided.
Posted on Feb 08, 2010
Wiring mex bt31pw cd player to 2003 hyundai accent with no wiring adapter. Need to know what color wire go to what on the vehicle
2003 Hyundai Accent Car Radio Stereo Wiring Diagram
Car Radio Constant 12v+ Wire: Orange/Black
Car Radio Switched 12v+ Wire: Pink
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/Orange
Car Stereo Dimmer Wire: Green/Black
Left Front Speaker Positive Wire (+): Red
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Brown
Left Rear Speaker Positive Wire (+): Green
Left Rear Speaker Negative Wire (-): Orange
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Black/White
May 01, 2017 | Hyundai Cars & Trucks
Toyota Camry 2003 V6 radio
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 16, 2016 | Toyota Cars & Trucks
I need information on what wires use fuses on a sony cdx-4000
You may find your Sony unit has the fuse built-in to the back of the player - hence, modern units no longer require an in-line fuse in the wiring.
yellow = 12v constant or battery power
red = 12v switched or ignition power
black = 12v ground or chassis ground
blue = power antenna turn on
blue/white = amplifier turn on
white = left front speaker +
white/black left front speaker -
gery = right front speaker +
grey/black= right front speaker -
green= left rear speaker +
green/black left rear speaker -
purple = right rear speaker +
purple/black= right rear speaker -
lt blue= cell phone mute input
Hope this helps...
Nov 01, 2011 | Sony CDX-4000X CD Player
Wireing diagram for a 03 gmc sierra pickup for a pioneer DEH-1200MP stereo please
Hello my name is Israel and I will help you. The following information will help you out. Please rate. Good Luck.
Feb 28, 2011 | Pioneer Car Audio & Video
When the radio is switched on, the speakers crackle then after a while the display shows failure and then the sound is clear
Check all speakers are still working you will find might find one isnt.
The message Failure means a speaker or amp incorrectly installed.
Mar 14, 2010 | Sony MEX-BT2500 CD Player
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
How do I install the Sony MEX-BT2500 wires?
http://www.docs.sony.com/release/MEXBT2500_install_EN_ES_FR.pdf
Here is a link to Sony installation wiring for your MEX-BT2500. You didn't say what car that you're installing in.
Oct 17, 2009 | Sony MEX-BT2500 CD Player
Sony MEx Dv 2000 does not play divx dics
i need to unlock region code for mex-dv2000
Feb 25, 2008 | Sony MEX-DV2000 CD Player
Sony Car radio cd bt5000 with US steping !!!!
I don't believe this is a user adjustable setting (at least it's not documented). Chances are, it is set within the firmware of the unit itself. Versions of this deck sold in Europe probably have a different version of firmware, allowing 0.1MHz FM increments. You might be able to talk to the European arm of Sony's support and ask them about updating the firmware to the latest European version. Keep in mind, putting EU firmware on a deck that was supposed to be used in the US could cause problems.
-=Zzed=-
Jan 16, 2008 | Sony MEX-BT5000 CD Player
Sony MEX-BT5000 CD Player Logo
457 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
