Question about Sony Handycam DCR-DVD201 DVD Camcorder
How to transfer video from camcorder to pc bcoz i have image mixer installed it is not happening dcrdvd201 it says usb driver does not support this version window vista home premium what do i do
  • 10,594 Answers
There is no need to hook camcorder with computer through USB, all is required to Finalize recorded DVD in camcorder and put that disc in computer to copy files for further editing etc.
Finalized disc in camcorder will be recognized in any other dvd player or dvd-rom.
Finalize disc option is available in camcorder menu.
Thanks.
Posted on Feb 05, 2010
WHERE CAN I DOWNLOAD JVC GR-DV700EK DRIVERS?
Drivers are not usually needed. Connect the camcorder to your PC with a firewire lead (preferred) or possibly a usb lead ( some camcorders only transfer still images via usb). Fire up your video editing software to capture the video from the camcorder to the PC.
Sep 30, 2012 | JVC GR-DV700 Mini DV Digital Camcorder
I have canon camcorder fs30 - I ahve recorded a video to the memory card. I have downloaded Image Mixer 3 (and the version upgraded to 4.51). When I connect to USB the computer does not reconize the...
i would try to access the "memory card" separately. assuming you have an SD installed. this would mean you have an SD reader on your PC as well. if you have both, windows explorer will simply pop up when you insert the SD card. if you have neither, then you have to get the device recognized. first, verify your usb works. try a USB key or thumb drive with files on it to verify it can be used...aka driver installed. if good then camera should be readable. connect with known good USB cable....substitute this out to make sure. make sure camera is on and has power. make sure your camcorder is in play mode - briefcase with play arrow. good luck.
please note manual - page 72 - 85
http://gdlp01.c-wss.com/gds/4/0300003144/01/fs30-31-300-nim-en.pdf
Jun 13, 2011 | Computers & Internet
My Sony Cmcorder is hooked up by my USB cord and I am not able to open it up. HELP
Do you have drivers installed for it?
Visit the following link and download drivers for it:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRDVD201
May 04, 2011 | Sony Handycam DCR-DVD201 DVD Camcorder
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Jun 07, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
PC does not recognise Camcorder when connect via USB Cable
my pc does not recognise my camcorder gr-d63 when connected
Dec 28, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Downloading video from cam corder
I would try the following:
1) check for an update to the image mixer software here
2) see if jvc customer support can/will help
3) uninstall the image mixer software and try using windows movie maker instead
Aug 21, 2008 | JVC Video Cameras
Can't transfer my DCR-TRV17E movie into PC
try to use ulead movie maker. its very easy to use. upload from camcorder to your pc with the use of ulead. edit it, and save it with any various types of videos. hope that helps!
CHARCOIS
Aug 21, 2008 | Sony Handycam DCR-TRV17E Mini DV Digital...
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Using USB
Before transferring digital images through the USB Connection, you must install the driver and software that came with your camcorder. The software may vary by model. Please view the attached instructions and system requirements for installing the software. Instructions for transferring images through DVC media are provided on the disk as well. For newer models, you can use Windows Explorer to transfer still images. After installing the driver as instructed in the attachment, follow these instructions. 1. Connect one end of the USB Cable to the Camcorder. 2. Connect the other end of the USB Cable to the PC 3. Power on the Camcorder. (You will notice a green arrow appear in the lower right hand corner of your monitor indicating the device has been detected by your PC) 4. Right click the 'Start' button and choose 'Explore' 5. The Camcorder will appear as a 'Removable Disk' with a drive letter. 6. Click on the Removable Disk and two folders will appear. DCIM and SSMOV. DCIM will contain still images. (SSMOV will contain mpeg's) 7. Double Click the DCIM folder 8. Double Click the folder named 100SSDVC 9. All pictures on the memory stick will appear. 10. You can highlight any (or all) pictures you would like to transfer and move or copy to them to the folder of your choice. (You can select a folder in the left window pane of Windows Explorer and drag and drop files as well) 11. When you are through, you must 'Safely Disconnect' the camcorder by right clicking the green arrow in the lower right hand corner of your screen. (Follow the on screen instructions. Failure to do so may result in flash memory loss)
Sony Handycam DCR-DVD201 DVD Camcorder Logo
273 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
