Question about Apple MacBook Pro Notebook
On startup the colours are not right, if you go to applications, click on front row, then escape, the colours go to normal but on restart the colours go back to the way they were
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
This may be auccring for Ram memory.Reset the smc and pram and check with saperate Ram.
Posted on Apr 12, 2010
Printer spooler service not running
The spooler is not on your printer it is in the Windows folder on your computer and is used to hold documents whilst preparing to print.
Normally this service is set to start automatically and there are a number of reasons why it may of stopped but try this:
Right click on "Computer" in your Menu and then left click on "Manage".
In the page that appears click "Services and applications" and Click "Services"
Navigate down to "Print Spooler" and double click on that line.
A box should appear showing properties of the Spooler.
It should show
"Startup Type = Automatic"
"Service Status = Running"
If neither of these are true then change the Startup type to Automatic
and click on the "Start Button"
The service will then either start or tell you why it cannot start.
Nov 21, 2013 | LG Computers & Internet
Tip
How to remove Run DLL Error on Startup
We normally face this problem that an error pops up whenever it wants
This normally happens because of some scheduled tasks in the operating system that you are unaware of .
Install Autoruns let it scan then find the exact path (as in your first post) and delete it. Reboot and see if you get the error message.
In order to scan these unattended , hidden tasks , please follow the below mentioned link to scan the Windows Sysinternals . And the file which is showing the error mostly shows up highlighted in yellow colour so its easy to identify .
https://technet.microsoft.com/en-gb/sysinternals/bb963902.aspx
Extract and run the application .
Delete the file that you get in Yellow Colour by the error and delete it .
Restart your computer and see if the problem is resloved .....
on May 17, 2016 | Miscellaneous
Error: GetFileText. BrowseIt. Permission Denied is popping up constantly
Let's put the computer in clean boot state and check if any third-party program is causing this issue.
Putting your system in clean boot state helps in identifying if any third party applications or startup items are causing the issue. If yes, you may have to contact the program manufacturer for any updates or uninstall and re-install the program.
Here's the article you may refer to for steps with reference to the same.
Use this link if you are using Windows XP:
How to configure Windows XP to start in a "clean boot" state
Note: After troubleshooting, make sure to put the computer to start as usual as mentioned here:
To configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows XP to start normally.
a. Click Start, and then click Run.
b. Type msconfig, and then click OK. The System Configuration Utility dialog box is displayed.
c. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
d. When you are prompted, click Restart to restart the computer.
Apr 15, 2011 | Microsoft Windows XP Home Edition
Startup fails to complete properly
When on the screen, and you have no icons hold control(ctrl) down and shift key and press escape(esc) your windows task manager should appear, goto the applications tab, at the bottom goto the tab New Task and left click, another window should appear with a text bar, type in the text bar explorer.exe and click ok, all the icons and your normal screen should reapear.
If your screen goes back to normal goto the start bar and goto run or search and type "regedit".
When the regedit window appears left click the " + " sign next to Hkey_local_mechine the the plus sign on software, scroll down to Microsoft folder and click the plus sign, scroll down to Windows nt folder and click the plus sign, the plus sign on Current version folder, then scroll down to winlogon folder and left click on the folder icon, on the right hand side of the screen look for "shell" double click on the icon and delete everything in the text bar and type explorer.exe and click ok and exit out of the window, restart the pc and everything should be back to normal.
pls post back and tell me what happens.cheers.
Jan 30, 2010 | Computers & Internet
"Webcam is in use by another application."
in ue by another app is usually a driver conflict or a virus. if you have a 3n1 printer or a scanner unplug it and reboot the pc see if you get the same message. if not update the scanner or printer drivers. if the messgae return even after the reboot try a clean boot next.
To Boot Clean in Windows Vista Accessing the System Configuration Utility
1. Click Start and select Control Panel
2. Click System and Mantience
3. Click Administrative Tools
4. Double Click System Configuration
Configure Selective Startup options
1. On the General tab, choose Selective Startup
2. Uncheck Load Startup Items
3. Select the Services tab
4. Check Hide all Microsoft services
5. Click Disable all
6. Click on OK
7. Click Restart.
After performing the necessary steps, restore your system by doing the following:
4. Double click System Configuration
5. On the General tab, choose Normal Startup
6. Click Ok
7. Click Yes, when asked to restart your computer
To Boot Clean in Windows XP
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. On the General tab, choose Normal Startup
3. Click OK
4. Click YES, when asked to restart your computer
if the camera starts to work after doing this your looking at a virus have your pc cleaned by a pro.
Jul 20, 2009 | Logitech QuickCam Pro 9000 Web Cam
CPU goes to 100 % usuage with more then 2 gigs memory installed
Firstly make sure that your BIOS doesn't have a configuration/setting for larger RAM installed and doesn't have any RAM paging configurations that need setting.
If Kingston tech support couldn't solve this, we can presume that the memory sticks and the motherboard memory addressing is good. To solve this you need to look for an application post-startup that is hijacking your CPU. It's then likely that you have an older application that when it addresses more than 2 gigs gets thrown into an endless loop and hogs your system. The following will identify and help you eliminate that application.
With your 2 gigs installed, do the following.
Click Start>Run and type in "msconfig". This runs the configuration utility that shows your startup programs and services. Select the "Diagnostic Startp" option , then click "Apply" and follow the restart instructions. When your system reboots select "cancel" when asked to restore the settings. This will keep these settings through the next steps. Make sure that your system works well in this diagnostic mode with the 2 Gigs. All those burdensome background running applications that sap your system resources will be eliminated (temporarily) and bare Windows can run unencumbered without being dragged down. Shut down your system.
Install the remaining 2 gigs. Reboot and see if the system still maxes out at 100% (make sure you leave it for a while to give it a chance to settle down).
Try your issue again. If this time it operates as normal without the system being maxxed out, you'll know that at least one of those startup applications is the culprit. Running msconfig again will allow you to restore the Normal Startup, and the Startup tab will allow you to remove selectively that application that is causing the issue.
One way to identify which one is the culprit is to restart normally (select the Normal Start option in msconfig and reboot) and once back up, do a ctrl-alt-del to bring up the Task Manager. Click the "Processes" tab and then click the heading "Mem Usage". This will sort running processes by how much memory resources they consume.  The memory hogs may not be the one giving you the problem, but it's likely that a heavy memory/resources consumer is also sapping the CPU cycles needed to operate normally. Make a note of the top heavy memory users (print a screenshot) and use this list to eliminate any that are also on the startup list back in msconfig.
Don't use the "End Process" button in the Task Manager to simply stop them, as you'll likely stop one that is critical to Windows functionality. Msconfig's Startup list just shows the ones that get started at Windows boot up and can be eliminated without crippling Windows - much safer.
Use your memory hog list to start eliminating, one at a time, the offending applications from the startup list until the issues is resolved. Its a little tedious, but helps clean up your system in the process.
Hope this helps, and please rate my answer.
Dec 31, 2008 | Evga (133-P4-NF51-AX) Motherboard
Xp windows explorer delay w/ "open with"
Sounds like you have too many background applications running that intercept right-clicks for their own functionality.
Click Start>Run and type in "msconfig". This runs the configuration utility that shows your startup programs and services. Select the "Diagnostic Startp" option , then click "Apply" and follow the restart instructions. When your system reboots select cancel when asked to restore the settings. Now all those burdensome background running applications that sap your system resources will be eliminated (temporarily) and Windows can run without being dragged down.
Try your issue again. If this time its quick and without the long lags you reported, you'll know that at least one of those startup applications is the culprit. Running msconfig again will allow you to restore the Normal Startup, and the Startup tab will allow you to remove selectively that application that is causing the issue.
The memory hogs may not be the one giving you the problem, but it's likely that a heavy consumer is sapping the CPU cycles needed to handle your right-click pop-up menu and run-with selection. Make a note of the top heavy memory users (print a screenshot) and use this list to eliminate any that are also on the startup list back in msconfig.
Hope this helps.
Dec 27, 2008 | Microsoft Windows XP Home Edition
I have a Photosmarat 2710, and my computer runs software Version X (not Vista). I can copy and print but not scan. When I try to scan it says I need to install or run HP software. The only software I got...
If in case the software is completly installed then try the steps mentioned bellow.
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Dec 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
MY HP PHOTOSMART DOES NOT GIVE OPTION TO SCAN TO PC
First make sure that the software is sucessfully installed in you computer and then try the steps metioned bellow.
Go To My computer>C:\Drive\windows>system32
Copy hpzipm12
Go back to My computer>C:\Drive\windows>system32
Copy hpzinw12
Now go to My Computer>C:\Drive\Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Tried to scan.
Dec 21, 2008 | HP Photosmart C5280 Printer
Home pc
hello,
try this,
click on start then run, type msconfig in command box,
system configuration window should show up. click on tab called startup. click disable all, then apply, then click ok, it should ask if u want to restart. please restart the computer.
what will it do? it will disable all startup applications.
if this resolves the issue, then you would know its one of the startup application causing your computer to freeze it.
also right click on bottom bar, then click task manager.
click on tab called processor.
average processor is 25-30.
in my laptop i have only 19 processor runnning.
if you have alot of processor running that definitly cause PC to slow/freeze.
hope this information help you
Dec 22, 2007 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Apple MacBook Pro Notebook Logo
112 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
