Question about Canon MVX10I Mini DV Digital Camcorder
I have inserted an 8gb SD card and it will not record
  • 2,153 Answers
If it is 8GB, it is an SDHC (high capacity) card. The protocol for SDHC is different than that for an SD card. SD card protocol handles a maximum of 2GB. This camcorder came out in 2003, well before the SDHC protocol was developed, and the camera is not compatible with it.
Posted on Feb 05, 2010
Records only 7 - 9 second :--(
check the sd card on your pc/laptop make sure its in fat32 format. check record settings, on record setting (4gb and above) set it to intervals of 15min. and save setting. sd cards over 8gb are prone to over heat or not record over as it needs to be able to record over older files. 32gb type you need a high end sd card for them to last the better the quality of sd card the better they last. you can also get a corrupted data file either on the video of the format. either way the ds card will need formatting again. hope this helps.
Aug 17, 2013 | everbuying GS8000L Full HD 1080P 2.7 Inch...
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
Samsung s1030 digital camera keep showing memory full but have inserted new sdhc card how do i clear this as i cannot take any pics
Clear it by putting in a compatible memory card. The S1030 works with SD cards. Your 8GB SDHC card in not compatible. You need to use SD cards, 2GB and smaller.
Sep 08, 2012 | Samsung S1030 Digital Camera
Can't get full use out of 8GB SD card.
There is no problem. The camera can only create video clips up to 4GB in size. You can record two long clips, but no single clip can exceed 4GB.
Mar 24, 2012 | Canon PowerShot A3100 IS Digital Camera
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
When i try to format the SDHC 8GB memory card the recording screen display's (Waiting....) for about 1 to 2 second's, then goe's to the normal recording screen and when i push the record button it...
Hi, look here's what to do, get yourself, or access to, A Computer, and a USB SD card reader, now, insert your 8GB SD card into the reader/writer, It will show up as a HDD in My Computer, and then, Format it FAT32. Now return it to the Camcorder, when turned on again, the Camera NOW should "See" the SD card. You may even be asked if you wish to Format,again,say YES, and do so, if NOT asked that;s OK too. as, you should now be able to, in either case, be able to have access to the SD card, and can change your phone settings accordingly, the extra storage will simply be "Picked Up" by the Camcorders software.
If this doesn't happen, then there maybe a problem with THAT SD card or the Camcorder? try another SD card before thinking the camcorder has a problem though.
Aug 29, 2010 | Jazz Cameras
I just bought a new memory card (8gb) for my digital camera (Samsung NV10) and when I inserted the memory card, I kept getting "Card Error". It said I should format the new memory card and I tried to...
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Aug 10, 2010 | Samsung NV10 Digital Camera
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
I only get 2minutes of video time after adding a 8GB SDHC card
There is small button on the card which needs to be unlocked so that the card is ready for recording. Also make sure you have changed the media from internal memory to Card in the settings section.
Thanks
Jan 25, 2009 | Cameras
I have the SD-1. It stops recording on my 8gb after only 43 min
Try formatting the card while its in the camcorder, this might sort the problem for you, also look in the camera's menu to see if its restricted to a certain amount of used memory at once, basically return the camera to factory settings.
I find a lot of camera's don't like certain SD cards anyway even if the camera says it supports them, Sandisc are making just about the best SD cards at the moment
kind regards
Dec 11, 2008 | Panasonic HDC-DX1 DVD Camcorder
Open Questions:
Canon MVX10I Mini DV Digital Camcorder Logo
124 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
