Question about Intel SS4000-E (SS4000ENA)
Unable to connect
Hi.
I have no idea what is wrong.
I've got Intel SS4000-e NAS.
Network is the same as in my XP.
There is LED showing system status and this LED after a few seconds is YELLOW all the time.
I can not to connect to NAS. I can see NAS using console, i can see IP but when i try to connect by FireFox there is a meesage FireFox can not open the web. Every time. With nad without hard drives.
  • steven_augus
    steven_augus Dec 20, 2012
    I am having a similar issue. I am trying to configure my console for the first time (amber light on the front) but when I go to Log On Storage System Manager the web browser (IE) can't open it.
  • steven_augus
    sry, hit return too soon.... Does anyone know what might be wrong? I've tried using a cross over cable AND a regular ethernet cable connection to my PC and in both cases it can find the storage box but I can't ping the IP address (or log in using the console). Any advice would be greatly appreciated!!!
  • 3 Answers
When the LED turns continuous amber colored , it means your RAID is not yet initialized.
- Install the Intel Storage system center console (ISSC) software from the accompagnied cd-rom
- Start the ISSC and have it discovering your storage device (make sure you are in the same subnet as your NAS device)
- Once it discovered the device click "Log on storage console" , it will open up a browser and have you login.
Firefox should work , I however assume you are maybe in a different subnet , and therefore cannot open the page.
If FireFox really doesn"t work , try using IE !
Posted on Aug 29, 2008
How to change my ditto mac address
The following procedure worked for me :
To change the MAC address of a Dane-Elec MyDitto Classic NAS, use the flash memory configuration hidden page :
http://(ip of your my-ditto)/flash.asp
- Enter the right MAC address (which is written on a sticker, under your my-ditto NAS... something like "001F1Fxxxxxx") in the field "NIC0 address:".
- Click the "Save settings" button. (The same page reloads, with empty fields : ignore it).
- Restart your my-ditto NAS (with the power switch).
After booting, the power led should stop blinking (stay lit), and your NAS should be available through PC client software (master/user usb keys) again.
If the problem remains or reappears (dummy MAC address again), the culprit could be the CR2032 lithium backup battery inside your my-ditto. In my 2-year-old NAS, this battery was too low (2.1V instead of expected 3V). To replace this battery on its socket, you have to open your NAS (voiding the warranty).
Good luck...Hope this helps someone !
cvoila
Sep 26, 2012 | Dane Elec Dane-Elec myDitto 1TB 2-Bay Home...
What is nas
network attached storage server using bsd.used for backup
www.nas.org
Feb 05, 2011 | Microsoft Windows XP Professional for PC
Can´t use INTEL SS4000-E to host the files of my database from SQL SERVER 2000
The SS4000-E  is a NAS storage server.  To the best of my knowledge it is not possible to put database files on a NAS.  They need to do on Direct Attached Storage.
Oct 22, 2008 | Intel SS4000-E (SS4000ENA)
Can't Access Public Shares via NFS
You can mount the shares something like this:
mount -t cifs -o username=backup,password=YoUrPaSS //192.168.0.145/projects /mnt/nas/projects/
...where 192.168.0.145 is IP of SS4000-E and /projects is the shares folder
and /mnt/nas/projects/ is folder you have created on your Linux box
Hope this helps
Best Regards
ashley
Apr 11, 2008 | Intel SS4000-E (SS4000ENA)
Tritton T-NAS 120GB Vista connectivity
did you ever have any luck connecting to your nas
Mar 09, 2008 | Tritton Technology T-NAS 120GB (trinas120)...
Can´t CONNET to AD
You have to make sure that the clock of your NAS is synchronized with the ActiveDirectory. Configure your NAS to use NTP. This should be under the clock configuration screen. Enter the IP address of your domain controller(s) as the NTP server address.
Also, it would be a good idea to make sure that you domain controllers are synchronized with a root time source (on the Internet). In order to do that, run the following command on all you DCs.
C:\>net time /setsntp:br.pool.ntp.org
Of course, your DCs must be able to access the internet on port UDP 123.
Judging by your email address, you seems to be located in Brasil. If you are not in Brasil, you may look for another NTP server http://support.ntp.org/bin/view/Servers/NTPPoolServers
Feb 02, 2008 | Intel SS4000-E (SS4000ENA)
Unacceptable startuptime software with databases on SS4000 as shared drive
@echo PLEASE WAIT, THIS MAY TAKE A MINUTE.
@ECHO PREPARING ROUTE FOR USING INTEL ATTACHED STORAGE
@ECHO MAY HAVE TO DO A MANUAL CLOSE AND DISCONNECT OF THE Z: DRIVE.
devcon enable "PCI\VEN_14E4&DEV_167A" <== modify for you
route delete 0.0.0.0 192.168.0.101
net use z: \\192.168.0.101\public storage /user:admin /persistent:yes
Oct 13, 2007 | Intel SS4000-E (SS4000ENA)
Unable to detect my router
This is because your router is setting your pc at a different IP address than your original modem. Make sure router is set to enable DHCP which gives out an automatic ip address and check your wireless card and network cards are set to obtain ip address automatically. It may take a few re-starts to get on the internet as your systems will need to clear their previous DNS settings. Also i assume you have set up the home network wizard (XP) as you are now using a router and not a direct modem. Also try Start>Run, then type ipconfig /flushdns then press enter.
Dec 27, 2006 | D-Link AirPlus DI-524 Wireless Router
Reset root password
see http://www.intel.com/support/motherboards/server/ss4000-e/sb/CS-022318.htm for an answer
Nov 04, 2006 | Fastora NAS-104 (nas-104d) 0.25 GB Hard...
Open Questions:
Greetings, I've been using the Intel Entry Storage System SS4000-E as a simple backup network drive for the last few years. It showed up as Drive Z: on all of my Windows machines and I just copied other drives/folders onto it as needed. It's far from the full capability of this device but it's suited my purposes. Recently, I decided to upgrade the drives and increase the total storage space from 2 TB (4 500 GB drives, Raid 0) to 6 TB (4 1.5 TB drives). The software doesn't allow me to make one 6 TB drive, so I made three (X:, Y:, and Z:), with sizes ranging from 1.49 TB to 1.99 TB, accessible as \storage\public3, \storage\public2, and \storage\public1 respectively. I also created the required shared folders using the minimum (200 MB) for both so I could have as much room as possible for large shared partitions. I also took the opportunity to upgrade the firmware to version 1.4, build 709, since I was installing new drives. I backed up some data to the Z: drive (\storage\public1) and filled about 1.5 TB. Then I started copying folders from another system to Y: drive (around 900 GB in all). Everything seemed to be going well until I looked in on the copy after around 800 GB had transferred. Files were being copied *extremely* slowly, like 100 MB in 10 minutes! I aborted the transfer and ran a test to eliminate network issues as the problem. I tried copying a 100 MB file from Y: drive to Y: drive. It took around 10 minutes, as above. I tried the same thing on Z: drive and it was almost instant. Something was somehow causing that part of the network drive to move at a snail's pace. I then accessed the management screen via a browser and got a message saying that one or more drives had either failed or been changed (Disk Change Notification - raid_disks_changedF.cgi). Two tables that show all four disks - serial numbers and capacities - are shown, one table being previous configuration and the second being current configuration. Both tables are completely identical. Clicking on "Scan" or "Continue" resulted in the same message, so I clicked on "shut down" and tried to access the network drive after it rebooted. I had no problem getting into the Z: drive part of it but both X: and Y: weren't being seen at all anymore. I'm aware of the fragility of a Raid 0 and wonder if it could be so easily disrupted during a large transfer such that I face the possibility of initializing all four drives and starting over. I'm at a loss as to what could be going wrong here or how to fix it. I really just want a simple means of copying lots of data over from various networked machines without any additional software. This system worked fine before. What could have happened? Thanks for any help. Bob
Apr 13, 2011 | Intel SS4000-E (SS4000ENA)
See all Intel SS4000-E (SS4000ENA) Questions
Intel SS4000-E (SS4000ENA) Logo
796 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
