Question about Dell 962 Photo All-In-One InkJet Printer
Printer read out states "lower exit tray" / - Dell 962 Photo All-In-One InkJet Printer
More paper was loaded so that the "Pick up" mechanism could
still work. It would seem that that the spring loaded paper pick-up mechanism was therfore the real problem - not the exit tray !
Posted on Feb 07, 2010
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: keeps telling me to lower
    Perhaps these images will help you. Steps shown is on how to load paper on your Lexmark X7170 printer.
    I hope this information has been helpful. Thanks.
    Posted on Jan 13, 2011
    How to output bin empty ?
    1. The output bin may be full. Empty the output bin. Printing resumes automatically.
    2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
    3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
    4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
    Jan 20, 2015 | HP LaserJet 5200 Printer
    Paper tray doesn't raise on my brothers hl5250dn printer. Says papertray empty
    I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
    Jan 30, 2011 | Brother Lower Paper Tray Feeder / Tray for...
    Keeps telling me to lower exit tray and press select. where is the lower exit tray located/
    Jan 07, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
    The printer shows an error message of "lower the
    1. lift the paper exit tray
    2. lower the paper exit tray again 3. press the select button 4. Resend your print job to continue.
    Dec 27, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Paper want go in to print
    The reason why it keeps saying this is cuz you paper feed tire needs replacing. Now i am not sure based on the cost of this unit if it would be worth to have this repaired but, this is what is causing this error.
    Jul 24, 2009 | Lexmark X7170 All-In-One InkJet Printer
    How do I stop daily reports from printing? How do I change the default tray for fax reports?
    To program a default paper tray to print fax reports, perform the following:
    1. Select Utility/Counter.
    2. Select User Setting.
    3. Select System Setting
    4. Select Paper Tray Setting.
    5. Select Print Lists
    6. Select the paper tray for the fax reports to print from.
    7. Press OK.
    8. Press Exit on the lower left side of the display to return to the copier screen.
    to set the activity report to not print daily
    1 touch the utility button
    2 touch administrator settings and enter the password 12345678
    3 press fax setting
    4 press report settings
    5 select activity report and change to off
    6 press close then exit
    Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
    I do not know how to the put the paper into the printer
    1). fan the paper
    2). there is a paper tray under neath the conrol panel. flip up the cover, pull out the extender.
    insert the paper short side in (8 1/2 x 11)
    3).squeeze the slide paper guides on the side of the paper tray rest against the edges of the paper.
    4).puhs in the paper entender, lower the tray cover.
    5). entend the paper exit tray stop on top of the paper tray tocatch the paper as it exits.
    Nov 13, 2008 | Dell 946 All-In-One InkJet Printer
    Printing
    Dear jamin4volks;
    As per this excerpt from the Oki B4350 User manual:
    "FACE UP AND FACE DOWN PRINTING
    For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
    For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
    Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
    This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
    Hope this helps;
    Frank
    Apr 18, 2008 | OKI B4350 Laser Printer
    Unexpected message: 6B22
    That is a pre heater fault.
    Preheater exit sensor in unexpected state during fault.
    Preheater exit sensor in unexpected state during stage.
    1. Check system grounds.
    2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
    3. Check the waste tray.
    4. Replace the Preheater ( REP 2.0.17).
    B2M
    B2N
    B2P
    B2Q
    The preheat flag tripped unexpectedly while picking paper from Tray 2.
    The preheat flag tripped unexpectedly while picking paper from Tray 3.
    The preheat flag tripped unexpectedly while picking paper from Tray 4.
    The preheat flag tripped unexpectedly while picking paper from Tray 1.
    1. Test the Preheater Sensor using Service Diagnostics.
    2. Check system grounds.
    B3M
    B3N
    B3P
    B3Q
    B3S
    B3T
    The preheat flag timed out waiting for the paper picked from Tray 2.
    The preheat flag timed out waiting for the paper picked from Tray 3.
    The preheat flag timed out waiting for the paper picked from Tray 4.
    The preheat flag timed out waiting for the paper picked from Tray 1.
    Preheater sensor timed out during stage.
    Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
    Dell 962 Photo All-In-One InkJet Printer Logo
    90 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
