Question about Nintendo DSi Black Console
In the sound record function it is silent when playing back the clip, and yes the volume is turned up
  • asal490228 Feb 06, 2010
    The volume bar does not work in the test mic function, have done an update as well n no joy. Is it time to take it back to the shop ?
    I have tried this and the mic bar does not light up so i have done an update and no luck so is it time ro go back to the shop and get it replaced
  • 644 Answers
It seems like from what you stated in your posts that you have a faulty microphone in the ds, if it is still in warrenty then yes your best bet is to take it back to the shop.
Posted on Feb 06, 2010
  • 2,069 Answers
Ok, now you should perform a MIC test first.
To verify that the Nintendo DSi's built-in microphone is working properly. How to test the microphone:
On the System Settings Menu, go to page 3, then select "MIC TEST."
Speak into the microphone. The volume bar will fill up with coloured bars when it picks up sound.
If the volume bar does not fill up, check whether anything is connected to the headset port.
If the volume bar responds, then the microphone is working properly.
Regards
Posted on Feb 05, 2010
Rc-50 recording silent wav files
Perhaps your computer's sound card is unable to play back at the bit rate and kHz you are recording at on your (mobile?) recorder. I'm not familiar with the RC-50 but if you are recording at 24 bit for example and your computer's sound card is only able to play back at 16 bit it may not reprosuce any sound. Usually you will get an error saying so. Have you tried different playback software?
Mar 22, 2014 | Boss Rc 50
I have a vivicam X225 camrera. I recorded a clip lastnight and when i downloaded it onto my laptop there was no sound. How do i change the volume or get the sound back? Please help
Hello Midda034 - Your camera has no video sound capability. It only shoots silent video.
You would have to have a higher quality digital camera for such features.
Sorry about the bad news and thanks for using Fix Ya.
Mikeywaf
May 08, 2011 | Cameras
Our church uses the Marantz Cd 633 Recorder. The problem we are having is that the playback volume of the CD is not high enough. You have to crank up the playback device all the way to hear recording at...
You have to isolate where problem is. Does a prerecorded disc play at normal volume levels? no? Check fade settings in menu. If yes, substitute another line level analog input from another device right at the recorders back panel. Test recording with that input and verify if recording level display can reach clipping level. If you have that and still have weak playback, again check for an in/out fade function being programmed. Also check volume selection in menu and try different settings, including 0.0. There is also a monitor mode to check input levels without using a test disc. Otherwise have unit checked by a repair business
Nov 22, 2017 | Marantz CDR633 CD Player Recorder
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
Sound of the recording after burnt to a cd is very low
adjust your top knob which is called the gain, this will allow the incoming signal to be muchlouder depending on where you set it , the bottom fader is for playback volume and mixing and you should also a avolume control for your head set , follow also the recording instructions in your manual for optimal settings , there,s no reason that your recordings should come out with low volume other then your gain control being set to low , hope i was able to help , if i was please leave a nice rating ,sincerely glenn mayer
Mar 09, 2009 | Tascam 2488 Portastudio Multitrack...
Audio in playback mode doesn't work
Hi There, Try this: Connect you camcorder to your tv set via a/v input cable. Put camera in cam mode so you can see the picture on the tv. Turn up the volume on tv and if it squeels, the mic on the cam is ok. Record something and then play it back on the tv, if its ok, then all your audio is functioning. This means that the SPEAKER on your camera is defective.
Thanks, mr cicmo
Dec 26, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Re: No sound
yup 9 proable dont suprt vista 11 verison will and beter
Jan 05, 2008 | Ulead VideoStudio 9
Sound Recording problem
Don't know if your problem exactly like mine, but playing back recordings in the camera always have weak sound. However when editing the clips using Imagemixer 3 on your computer, the sound is louder and you can boost it even further with the "Adjust Volume" function of Imagemixer.
Bernie
Sep 01, 2007 | Panasonic SDR-H200 Camcorder
Movie mode function
The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Nintendo DSi Black Console Logo
50 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
