Question about Gestetner DSc224 Copier
MY COPIER GESTETNER 1302 PRINT HALF PART OF A4 AND THE OTHER PART PRODUCES LINES, WHAT MIGHT BE THE PROBLEM?
    President:
  • 3,085 Answers
Replace the drum.
Posted on Feb 05, 2010
I have a Gestetner copier. When I make a copy, there are lines on the right side of the copier. The lines are not solid-except for one. There are 8 lines. It covers about 1/4 of the page. The lines...
Try to make a copy on the copy board glass are the lines there? If not, make a copy using the adf, if they are there you need to clean the smaller , thinner piece of glass to the right side of the copy board glass. Good Luck
Sep 06, 2013 | Gestetner DSm725 Color Copier
I have a gestetner dsc460 copier. I am going to
okay your machine has the finisher option and punch option? if so when you go to print click file, then print. when your window opens for the printers select the gestetner. then choose properties. then choose printing prfeerences. then choose punch
Dec 31, 2009 | Gestetner DSc460 Copier
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
Copier Only prints half the page
Sounds to me that the paper tray is set incorrectly. There is a dial on the back of the machine that needs to be set correctly once the paper tray guides are adjusted accordingly -particularly when running 8 1/2 x 11" (letter) size paper. It can be set to run either lengthwise, or laterally (portrait) make sure the dial is set to the proper setting on ALL trays. If the tray is set for lateral, for example, and the paper is installed lengthwise, the scanner only utilizes 8 1/2" in length rather than the full 11". Frequent jamming is also a common problem when making multiple copies, because the paper is not where the machine "expects" it to be. Also check that the LCD display reads the proper size / orientation after adjustment.
Hope this helps. Please rate solution :)
May 21, 2009 | Gestetner Copier
Toner lines randomly appearing throughout copies
Clean the ADF slip glass..  try printing a counter sheet   USER TOOLS /COUNTER/ print if the lines do not appear on this print the problem will be with the optics.. good luck
Apr 22, 2009 | Gestetner Copier
Black streaks on copies. Gestetner 1302 How do I get rid of them
Do the streaks appear when you use the contact glass or just when you use the Automatic feeder?
If both, then you need to replace either the (drum unit) or the fuser roller(s).
If it just happens through the auto feeder, then lift up the "feed-in section" (left side) and clean the narrow scanner glass.
Mar 11, 2009 | Gestetner DSc224 Copier
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
A4 to A3 not working
hey guys with 1520p printing preferences you may use the zoom feature to print it out on an a3 size from a4 size of your document page setup
Feb 14, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
108 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
