Question about LG Washing Machines
How to a 5.5kg Top Load LG Washing Machine WFT556
  • 1294 Answers
SOURCE: washing machine
Possible your outlet filter is blocked, find it and clean out. Look into yr users' manual
Posted on Sep 15, 2007
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
SOURCE: error code 131
http://www.docstoc.com/docs/25379715/Fisher-_-Paykel-Washer-Diagnostic-Fault-Codes/
A;; fault codes above.
Posted on Apr 08, 2010
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
LG 5kg fuzzy logic model WFT5005T Top Load and it keeps screening PE and I don't know what it means.
PE stands for Pressure Error. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Apr 23, 2017 | LG Washing Machines
My machine 5kg how many cloth put in side like pant shirt
hard to say--- kids pants and shirts or 5xl pants and shirts
best gauge is just to drop the clothes in loose and when they are around near the top of the agitator , that is a load
Aug 13, 2016 | Washing Machines
I have an lg 5kg washing machine WD-80264NP which stops after washing for while.it doesn't spin. what could be the problem?
Ur timer switch for washing/spinning is broken, there are contact points on that timer switch, the part of SPiNNiNG is not functioning!
Let a technician check on that, and might as well replace it!
Nov 29, 2010 | LG Washing Machines
Need user manual for whirlpool AWG 5061/M --600RPM AA 5Kg
I NEED USER MANUAL BOOK FOR WHIRLPOOL FRONT LOAD W/ MACHINE MODELS NO AWG-5061/M AA 5KG 800 RPM please send it to me on fayaz_1966@yahoo.com I will be greatful to you Thanks
Nov 03, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
LG top loader slapping noise in wash cycle
Its not the usual problems found on Lg machines. sounds like you have possibly one or more coins being picked up underneath the pulsator. To check, remove pulsator with screwdriver and check .Very possibly you have a bra cup spring caught between the two drums which make an akward sound.
Jan 27, 2009 | Washing Machines
Water flow very very slow though the pressure from main tap is fine
almost certainly not a fault with washer. check small filters in the fill hose and make sure hose not kinked
Jul 18, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
87 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
