Question about HP Officejet 9110 All-In-One InkJet Printer
Need to replace a fax modem for HP Officejet 9110 which was pulled in order to use machine on a secure system. Now want to remove from network and use as Fax only. Need model/make of fax modem to install on HP Officejet 9110
    President:
  • 2,992 Answers
Other than some minor pieces and accessories, HP doesn't make too many parts available direct to consumers. Almost everything on the parts page for this model needs to be ordered through HP's reseller network. Try contacting one of those vendors to see if they can identify and supply the part you need. (The only name I recognize is Vance-Baldwin; they were our preferred vendor when I was in service for a large retailer.)
Posted on Feb 05, 2010
Connect fax from 6210 to phone via cable modem (VoIP)
In Order to use a Fax functionality of the router you need to connect the small RJ11 cable for telephones on the printer port. These printers do not suppoer VOIP Fax. To use VOIP as fax you can purchase a online VOIP subscription where you can scan and fax the documents.
Feb 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Driver needed for hp 9110
Thank you for your continued cooperation in addressing this issue. Your patience is very much appreciated.
In order to scan with your all-in-one, you need to install the scanning software from the Starter CD1. Please click the URL below to place an order online for the Starter CD 1:
https://warp2.external.hp.com/Driver/dr_country_select.asp?From=BSC&Product=C8140-10001
Also, you may call HP Customer Care at 1-800-474-6836 (800-HP-INVENT) to order the Starter CD 1.
Please e-mail back if you need further clarification and we will be glad to assist you.
Once again, thank you for contacting Hewlett-Packard's Commercial Solutions Center.
With regards,
Peter
Dec 19, 2008 | HP Officejet 9110 All-In-One InkJet...
HP Officejet 9110
where vcan i get the installation disk for my hp 9110 officejet all in one printer
Nov 04, 2008 | HP Officejet 9110 All-In-One InkJet...
CD OF HP OFFICEJET 9110 DRIVER COMPLETE REQUIRED
Make sure tomention the operating system on which you need to install the printer,
Try the link bellow and select the operatig system on which you want to install the All-In-One:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=376172&taskId=135&prodTypeId=18972&prodSeriesId=376170&lang=en&cc=us
Good Luck
Sep 19, 2008 | HP Officejet 9110 All-In-One InkJet...
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Mar 04, 2008 | HP Officejet 9110 All-In-One InkJet...
Fax report stuck in queue
try unpluging the power from the fax machine/
Jan 09, 2008 | HP Officejet 9110 All-In-One InkJet...
Installin hp 9130 all in one without install cd
Contact hp & order a CD
If the download was not working this would be fastest & easiest solution.
What is your operating system?
Dec 06, 2007 | HP Officejet 9110 All-In-One InkJet...
Erase faxes in memory
I had the same problem and wanted to remove confidential faxes from memory in order to be able to sell or donate old T45. Manual does NOT help.
My solution is based on fact that I have a separate FAX and voice line. I connected my Windows machine (which has a fax/data modem) to my voice line and faxed a large (80 page) software manual to the fax machine. This fills the available memory, thus erasing the old documents. (To save paper, remove paper supply first, the fax machine will still receive and store the document.)
Nov 20, 2007 | HP OfficeJet t45 All-In-One InkJet Printer
HP Officejet 9110 All-In-One InkJet Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
