Question about Belkin (F5D7231-4) Wireless Router
Why is my two pc interfering with each other using belkin wireless g
2 Suggested Answers
  • 19 Answers
SOURCE: I keep losing my signal
your gonna need the belkin router amplifier for that if its too far away from the router its gonna loose signal and cause you to intermittinly loose signal and connection ./... you could also contact belkin support at www.belkin.com/support
Posted on Jul 19, 2008
I am having difficulty connecting to Cisco VPN, could the router be interfering with this
The router could be blocking it. On your belkin router, check to make sure that ipsec vpn pass through is enabled.
Mar 18, 2011 | Belkin Basic Wireless Router
Belkin n150 game lag
i have had the same problem.all i did to fix it was stop using wifi and get a connected connection and now i have great signal.
note: i believe wifi/wireless can be interfered with other wireless things in your home such as phones, bluetooths, etc.
Jan 02, 2010 | Video Game Consoles & Games
Router is not connecting with my laptop in my home or my ipod touch.
Questions:
Did it just start, or has it happened before, if so, how often?
I've found that I have to reboot my Belkin router, usually daily!
What I've found was my wireless headphones were interferring with the wireless channels on my Belkin. I ended up unplugging my wireless headphones while on the internet, then plugging them back when I wanted to use them.
I even went into the router's software and changed the wireless channel to see if that would help, it didnt.
Things that I found to interfere with Belkin Wireless Routers:
1. wireless headphones
2. cordless phones
3. UPS (uninterruptable power supply), (SOME) for some reason it's emitting frequencies within the wireless band of the router.
4. Cable In-House Amplifier
5. Ive had two really weird ones, a microwave oven and a clock radio. I traced those by switching off circuit breakers, until the problem quit.
Work-around Solution, Ive had to move my router as far away as possible from these sources, or these sources away from the router, except of course my wireless headphones, didnt matter where I put it, it still affected the router. Hope this helps.
Nov 30, 2009 | Belkin Computers & Internet
Cell phone interfers with router takes modum off
You need to change the wireless channel on your router. I believe your router is set to Auto channel. Open the router's setup page by going to http://192.168.2.1 and look for wireless tab. Change the channel to 11 and save the settings. The reboot your router. It should't interfere with your cellphone now.
Oct 22, 2009 | Belkin (F5D5231-4) Router
We have Belkin Wireless Travel Mice FSL017-USB in are school and they are interfering with each other from as far as 30ft away in a class across the hall.
don't use wireless mice from the same company it is bound to have crossed "Wires" so to speak, buy Wired mice instead, they work better in the long run, and have no need for batteries.
Sep 16, 2009 | Computers & Internet
My Computer is going toooooooo slow !!!!!!!!!!!!
theres a million things that can interfer with wireless...tin...cell phones, cordless phones and the like..but 11mbps is still really fast and chances are, your internet connection isnt even half that so your speed on the net shouldnt be effected...1mbps is usualy enough to load any website in seconds.
if your PC is slow, not jsut on the internet but in general (starting up, running apps) then its an issue with the pc and not the wireless.
but as a heads up, not trying to be mean, but netgear and belkin are cheap equipment.
Apr 26, 2009 | NetGear WGR614 Wireless Router
I keep losing my signal intermittently on my Belkin MIMO plus wireless router it constantly goes up and down from 1.0 Mbps to 54.0 Mbps interferring with my connection. The router is connected to my...
Jul 19, 2008 | Belkin Computers & Internet
Can't connect wirelessly to Belkin Router
have you customized the wireless settings of you router (e.g. ssid, wireless channel, wireless security)? if not, try to change your router's ssid or the wireless channel. it could be that some wireless devices are interfering with your signal.
hope this'll help you.
ciao!
Jun 20, 2008 | Belkin (F5D5231-4) Router
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Problem with belkin router
assuming you are connecting wirelessly; you may have to check that the router is allocating ip addresses automatically to your pc's. connect one of your pc's to the router via the RJ45 network cable that was supplied and not wirelessly and type 192.168.2.1 in your internet browser, this will take you into the routers setup menu. Look for a menu refering to 'DHCP' and make sure that this is enabled, then look for the channel number that the router is using (normally 6 or 11) and make a note as if you are still experiencing signal loss, you can get back into the router and change to any channel between these numbers incase you are getting appliances interfering with the signal, save and exit from the router menu. disconnect the cable then go to control panel, network connections and right click on the connection you are using whether it is wired or wireles and click on properties. Look for the line TCP/IP and again click on the line and select properties, then make sure automatically obtain ip address is selected, ok and close window. Restart the pc's and you should have a connection.
Jul 08, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Belkin (F5D7231-4) Wireless Router Logo
27 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
