Question about Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
Pictures turn out too bright or too dark...
It doesn't matter what setting (Auto, Manual, Preset, Program) I have my camera on, it always has difficult figuring out the lighting.. the first picture will be way to bright while the second picture will turn out completely black. My friend tried to say it was on the wrong setting but we put it to the test and we just can't figure it out...
    Brigadier General:
  • 11,967 Answers
Go into the menu and find "reset"...follow the on-screen instructions.
Posted on Feb 05, 2010
Very dark video output and view through the view screen, no matter where the ISO dial is set. The Auto, C1 and C2 mode for Photos is just as dark. I can take good pictures only in P (Program) mode, al
This is most often a problem with the imaging sensor and no reset is going to repair the part. Also, if replacing it, it needs to be properly calibrated after installed. If you need help with this, this is the place we recommend for the Canons: www.CamerasAndParts.com They are the best for these models, they only work on Canons and they are excellent for repairs. They have a service package for about $90 which takes care of an image problem as you have or you can try emailing them first. As far as service and the quality of work, I wouldn't go anywhere else but them for a Powershot. They are the best for these cameras. Good luck
Dec 20, 2014 | Canon PowerShot G10 Digital Camera
Pictures too dark
just change the backlight and contrast settings in camera .....regarding flash try taking photos with new batteries ...
Aug 20, 2008 | Canon PowerShot A540 Digital Camera
SONY DIGTIAL
You never should use the picture you see on the monitor of the camera. Not one camera has a calibrated screen. And the brightness is changed very easy in the setup menu.
To test if your camera shoots good pictures, select AUTO on the mode dial. Shoot some pictures and look on the PC or just print them.
Your camera has so many settings, that over rule the brightness when you switch to it, like + and - 2 EV setting. But when you chose for A, P, S, or M, the pictures can be to dark or to bright, if you dial in the wrong settings. So don't evaluate the pictures on the monitor. Only use the histogram on your camera to see if you have a correct, to dark or to light picture.
Jan 06, 2014 | Panasonic Lumix DMC-TZ3 Digital Camera
My camera over exposes everything - the shutter stays open for about 2-3 seconds. except when on video settings. No matter what I set it at nothing changes.
Looking down at the top of the camera, check the left knob. This is the exposure compensation dial. Adjust it to "0". If set one way or the other, it will make pictures darker or lighter. This comes in handy when the image has a lot of dark or bright areas - moving this dial will allow you to make the bright areas darker or the dark areas lighter when you camera's light meter is setting the exposure in a way you do not want.
If still having trouble, make sure the right knob (Mode) is not set to M or Manual. Switch it to Program or Auto and try taking a picture again. You might even want to set the outer knob (ISO) to AUTO as well to reduce the chances of an incorrect setting. If it now works as expected, but you want to shoot in M, you will need to learn how to use the meter to select the correct combination of aperture (f stop), shutter speed and ISO to obtain the desired results.
Oh, experiment with the exposure compensation knob when you have a chance, learn how it can help correct overly dark / bright scenes. Good luck!
Feb 14, 2012 | Canon PowerShot G10 Digital Camera
Pictures too dark. Shutter operating too slowly.
Are you in auto mode? If it is manual then it is possible that the settings are not correct for the light. You can look at the meter to see what the camera thinks about the exposure.
It sounds as if your subject is too dark. Does this happen when the area is brightly lit? Does the flash fire?
May 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Pictures are too dark or too bright with Sony DSC-P200 Camera
U have an electronics issue with the circuitry controlling the light levels reaching inside. Have you tried using manual settings? Repair on those units is expensive and it may bot be a cost effective repair situation.
Mar 22, 2017 | Sony Cyber-Shot DSC-P200 Digital Camera
Pictures too dark
The settings in Auto Mode are factory set. If you want to adjust exposure and shutter speeds then you will have to shoot in Manual Mode (TV=Shutter Priority, AV=Aperture Priority, M=Full Manual)
May 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Dark Pictures in Auto setting
Do you have a polarizing filter on the lens?
Aug 07, 2007 | Canon EOS-20D Digital Camera
Finepix 2400 Dark landscape shots
I was just out yesterday taking pictures in very hazy conditions, and some of my shots were facing south at about noon. I was actually expecting the sky to be overexposed, so I took two pictures of everything, one on auto, and one on manual with the exposure set to -0.6. Well, it turned out that even the ones on Auto were dark, so the ones on the manual settings were even worse! As it turns out, I had the same problem you had, and should have boosted the exposure. Reading the manual, it does say that you should use positive compensation for very bright scenes or pictures of mostly sky. Try it next time and see how that works. I'm new to this too, but I'll get the hang of it sooner or later... ;)
Sep 04, 2005 | Fuji FinePix 2400 Zoom Digital Camera
Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
