Question about Kodak EASYSHARE V1253 Digital Camera
Kodak v1253 when try to switch on the lens stops in the middle
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 05, 2010
Kodak v1253 camera turns off when zoom lever is activated
Maybe the lens movement is sticking and causing additional overload for the camera circuits, thus causing it to shut down.
Dec 21, 2013 | Kodak EASYSHARE V1253 Digital Camera
My problem is that the lens stays open, all the lights flash, I hear a very low set of tones and then it shuts off. I recharged the batter and tried all the fixes except taking it apart
Sounds like a stuck lens. Happens to V1253 / V1233 often. These lens can't stand dust, dirt or sand. The lens has to be taken apart and cleaned. It's not very easy, also it involves some soldering. I suggest you give it to a local repair shop (if you think it's worth it). I could offer you a repair, but I'm in Germany.
I have worked at a Kodak service center as a technician.
Tom
Mar 04, 2011 | Kodak EASYSHARE V1253 Digital Camera
The camera switches off immediatly after switching it on, an the lens is not closing anymore. Is there a way to reset the camera with a combination of the buttons?
Not really, but it's most likely a lens problem. Resetting wouldn't help anyways. I have repaired a lot of these V1253 / V1233 with such a problem. It has to be taken apart and cleaned. Sorry for the bad news. I have worked in a Kodak service center.
Jan 23, 2011 | Kodak EASYSHARE V1253 Digital Camera
I have a kodak easyshare v1253 and the unit turnes on, the lights activate and the lens clicks to try to open the unit turns off. The lens does not open. I sent it in for warrnety for the same problem a...
Im sorry about that, well anyway it seems that the lens of your camera is already defective,
are you using the recommended battery Lithium-Ion battery (KLIC-7004)? If yes try to charged the battery and if this issue not solve Please call kodak Toll Free 1 800 235 6325 canada and U.S support only
Nov 03, 2009 | Kodak EASYSHARE V1253 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
The lense pushes forward halfway when turned on
Hi!
I'm afraid you will have to give it away for a repair - it sounds like the lens get stuck in the halfway - could be dirt, sand or something in the reductor or the lens are damaged.
I work in a Kodak service center.
Hope this helps!
Tom
Jul 29, 2009 | Kodak EASYSHARE V1253 Digital Camera
Easy share V1253...will not stay on...lens will not telescope
I have had the same issue were the lens would not retract. took it in for extended warranty work. lens now retracts but takes lousy pictures.
When I purchased this camera family members ran out and bought thiers shortly after I did. One by one the same issue has happend to their v1253's.
I dissmantled one and found that there is a tiny battery on the power board inside of the camera. apparently the tiny battery's life is about 1 1/2 years. This battery is not serviceable as it is welded in place. I am not one hundred percent sure if this is the cause but it makes sense.
It would be nice if kodak would own up to this issue and make good on repairs as they did with my kodak 5500 all-in-one printer and it's crappy print head. Kodak has sent me 4 print heads in the 2 years I have owned it.
I have 5 of the v1253's in my family and every one of the are dead. I would think a $250 product should last longer than 1 1/2 years.
Hope this helps you out.
Jul 01, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed on a kodak v1253
I fixed my v1253 following these steps:
1. Pulled the battery when the lens starts to come out before it could power itself off.
2. Gently pull the telescope out until it clicks.
3. Use a fine tip paint brush to clear debris out of the cracks.
Camera works just fine now.
Jan 30, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed will not retract, canon pc1147 zoom
hope this helps.
Aug 16, 2008 | Kodak EASYSHARE V1253 Digital Camera
Kodak EASYSHARE V1253 Digital Camera Logo
414 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
