Question about Alpine MRD-M1005 500W x 1 mono subwoofer amplifier Car Audio Amplifier
Help!!!! What is the best subwoofer for alpine mrd-m1005?
  • Tygh Duval
    Tygh Duval May 11, 2010
    There are many factors involved with selecting a subwoofer:
    • Budget
    • Music type
    • Sound quality or SPL?
    • Budget
    • Box type
    • Preferred subwoofer size
    • Budget :)
    For the most part, how much $$ you have is going to narrow down the field the most.
    Sergeant:
  • 300 Answers
I would say any decent pair of 12" or 15" (single 4 ohm voice coil) subs that can handle at least 500W rms would work. The rest is going to be based on cost, type of box, type of music, etc.
Posted on Mar 27, 2008
How hot does the alpine Mrd-m1005 amp get before the fans start cooling it ??
Fixya has no idea , suggest you check with the manufacturer ALPINE
Nov 28, 2017 | Alpine Car Audio & Video
My alpine Mrd-1005 has been best amp ever. But the other day it all of a sudden started blowing fuses on the amp and the current protecter mode kicks on.. as long as I keep volume down in works but as soon...
make sure there is equal amps on the fuse under the hood and at the amp...also make sure to never mount your amp to anything metal....wood only! hope this helps, mine did the same thing
Sep 04, 2011 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
When I hook my JL W7 sub to my alpine mrd m1005 amp the sub is pushed out and stays that way
Hello christensen7,
It sounds like there's DC current on the amp output terminals. Disconnect the sub and test the output with a multimeter. If there's DC there, most likely the amp is shorted internally and needs repair.
Hope this helps.
Aug 17, 2009 | Alpine MRD-M1005 Car Audio Amplifier
You need to have the amp bench tested at a car audio shop. Sounds like a dead short in the amp. Try turning the crossover on the sub "off" and connect any other speaker to it. if you have the same outcome, your amp needs serviced. Post a comment with your results and if I can think of anything else you could try beyond that I will. Hope this helps
Aug 17, 2009 | Car Audio & Video
Mrd-m1005 amp fans not never turned on?
the fanns will come on around 75c they are preset 60 is not that hot for an amp but the cooler you can keep it the better it sounds
Nov 27, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
No sound from the amp
Make sure that your amp turn on wire is connected from behind the radio to your amplifier. Usually the turn on wire is a blue wire but it can be any. This blue wire connects from the blue/white wire behind the radio to your small connection turn on connector on the amps power connections. You have 3 ( 12V , Ground, Switch or the smallest connector)
Also check the amplifiers fuses, and the main powerline fuse as well. If this doesnt work then write back to me.
Oct 10, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Car Audio & Video Logo
124 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
