Question about Motorola Mobility MOTORAZR maxx V6 Cellular Phone
My phone is not working, its not turning on anymore. it doesnt have any battery problem.technician said that theres something wrong with the program
Keyless entry for my 2005 Colorado does not unlock the doors or disarm the alarm. The second one does not either, but the battery was replaced in my primary one anyway.
You may need to reprogram them or the primary may be bad, try replacing the battery in the second controler and see if that works, if that one works then something is wrong with the first one, if the second one doesnt work after the new battery then you may need them reprogramed . if reprograming doesnt work then theres a problem with the keyless entery module, there are instrucation in your manually on how to program remotes.
Oct 13, 2010 | Chevrolet Colorado Cars & Trucks
My power button doesnt work anymore
Mine turns on when I plug the charger into it. Have you tried that?
Jul 04, 2010 | HTC Hero Smartphone
Power button doesnt turn tv on. wont power up.
Try replace the remote old battery with new ones.This should works.
If still won't power up, try pushing the channel button on the TV, if still won't power up, there's must be something wrong with the inside parts, find qualified technicians or service center.
Mar 07, 2010 | Televison & Video
I charged my battery yesterday and waited until it was fully empty. Now the battery doesnt want to charge anymore. I thought something was wrong with the phone and I entered my other battery. It is now...
There is nothing related to battery in this case, I guess. There may be problem with your charger connector. Just put the battery to another mobile and try charging. It it works then the problem is with your mobile connector only. You have to use genuine compactible charger for your mobile.
I hope this is helpful to you.
Nov 07, 2009 | Computers & Internet
Caller ID doesnt work anymore
see if it is turned off at the provider. ring and ask for the codes to turn them on and off.
May 30, 2009 | Uniden TRU9480 Cordless Phone
HTC Touch HD heating problem.....
dont forget you should be closing off the programs in the top right hand corner (pressing home or changing program doesnt close the program so make sure you are usually only running about 50%) and yes it is normally hot my friend and i both have one and we have already seen that both our hd's are quite hot on the back but not scorching... the bat should take up to 4 hrs most to charge off a wall and with regular txting and small (1-10 min calls) a couple of times a day and a little bti of web browsing the phone bat should last a day least.... (again make sure in setting wifi is off when not using and under settings/connections tab/com manager that this is all turned off (just to make sure)) especially remember that even closing the web browser in top right hand corner can leave 3g running so click on the 3g icon (depending on provider) on the top tab and disconnect it (also save u data usage)) atm im running for about 2 days off a charge at least and all i have done recently is reflashed my rom off the htc web site and whenever not suing the phone put it to sleep using the top power button (one press but im sure u all no).
Hope this helps! :D (great phone when you learn how to work it!)
Jan 22, 2009 | HTC Touch HD Smartphone
The m button on my side kick doesnt work anymore?
Is there something stuck under it? Sometimes crumbs can get under there if you aren't careful. Try blowing into it to see if there is something stuck that you can get loose. If this doesnt work, it probably means your phone needs to be fixed. Good luck.
Jan 13, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Losses its battery charge within 3-4 hours
Is the telephone reception ok? If there is a reception fault this may cause the phone to continuously look for a signal and wear down the battery.
Aug 29, 2008 | Nokia N95 Cellular Phone
Battery dead, boost car, cd player doesnt work anymore...
Get a testlight or DMM and test all of the power wires. It's your only hope.
Nov 04, 2006 | Panasonic CQ-C5301U CD Player
Motorola Mobility MOTORAZR maxx V6 Cellular Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
