Question about Sony Xplod CD Player w/MP3 Playback CDX-GT50W
Sony cdx-gt50w i've got this problem where i've wired every thing in as you do, & i've come across a problem where i cant seem to pick up any even numbers on the radio i.e FM.can any one help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Go over this detailed wiring instruction, make sure your memory wire is attache to a constant power source.
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Feb 20, 2008
I recently installed a sony explode in my truck everything works fine except for when u put a cd in, no sound and the display shows the cd is playing and all the function buttons work i just have no soud...
It sounds like you are using an amplifier. Make sure you are using the blue/white wire to turn the amplifier on. The blue/white wire is amplifier remote turn on and the blue wire is power antenna remote turn on. The blue wire turns off when leaving tuner mode, turning the amplifier off.
Aug 24, 2011 | Sony Xplod CD Player w/MP3 Playback...
How do you switch the rear outputs to sub outputs
This is a link to Sony for your CDX-GT50W Operating Instructions. Reference page 9 for subwoofer volume selection / adjustment.
http://www.docs.sony.com/release/CDXGT50W.pdf
It looks like you don't switch the rear rca outputs to subwoofer mode. There is a different output for subs as shown in box #3 of the link below.
http://www.docs.sony.com/release/CDXGT50W_Install.pdf
Dec 28, 2009 | Sony Xplod CD Player w/MP3 Playback...
HI there, I'm installing the sony explode deck in my car to an amp, and then two speakers, I can't seem to get anything but bass....frustrated...
Its your settings on the amp. There is a noise filter to set it for bass or for high. Just move the switch. If it is set right turn the lph and vph the opposite way the it currently sits. That should fix your problem. If it doesn't check your stereo. If you have it ran through av cables to the back of the system it most likely has a bass filter built in. You have to get the high input wire clip and run it that way.
Jul 08, 2009 | Sony Xplod CD Player w/MP3 Playback...
Sony explod,every thing works but the radio
MAKE SURE THE HOOK UP IS TIGHT IN THE BACK OF THE UNIT.
Jun 17, 2009 | Sony Xplod CD Player w/MP3 Playback...
Stereo notworking in ford focus
ahve you check you have put the blocks connecters onto the correct ones, or a cable may have came ouyt of the block.
May 22, 2009 | Sony Xplod CD Player w/MP3 Playback...
Problems with car audio
you should plug in the new harness and meter the wires to make sure there is power on two of the wires one will always be powered for memory the other should be powered when ignition is on if both test ok then check the in line fuse links on the radio wire harness I hope this helps good luck....
Jan 10, 2009 | Sony Xplod CD Player w/MP3 Playback...
CD PLAYER NOT WORKING
I would check both of the in line fuses on the on the wire harness on the back of the radio good luck the other thing it might be is a security feature tha may have the radio locked up good luck....
Dec 01, 2008 | Sony Xplod CD Player w/MP3 Playback...
How to set time on sony CDX-GT50W
press and hold the volume control dial. when a menu appears press the volume control button until clock adj appears. then press seek to change from hours to minutes. to adjust the hours and minutes just rotate the volume control dial
Apr 22, 2008 | Sony Xplod CD Player w/MP3 Playback...
Sony Xplod CD Player w/MP3 Playback CDX-GT50W Logo
194 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
