I took the bottom plastic cover off to clean the hair out of the roller. Somehow I managed to pop the roller out on one end and eventually got it back in the slot. I got the cover back on but now there is a horrendous noise when I try to vacuum. The only problem I was having prior to my repair attempt was a loss of suction due to a ton of hair being wrapped around the brush.
Sometimes the brush bar may be slightly bent and has been rubbing against the yellow housing part (at the hole where the belt is) and has melted part of it off, the part which holds the brushes in place. The noise may the bar vibrating against the yellow part because they are now loose. Unfortunately you may have to replace both parts.
