Question about Hotpoint First Edition WMA22 Front Load Washer
Water coming out of soap drawer - Hotpoint First Edition WMA22 Front Load Washer
    New Friend:
If your front loader has a gap between the gasket and the tub, take a flashlight and check to see that nothing is lodged in this area. I found one of my baby's bibs in this space and removed it with tweezers. I have no idea how this was causing water to come out of the soap basket (since the bib would spin with the tub and couldn't always be blocking water flow into the tub), but it fixed the problem. Also got rid of the squeaking noise and reduced speed during the spin cycle.
Posted on Apr 07, 2013
  • 712 Answers
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Posted on Feb 05, 2010
SOURCE: water coming from soap drawer
take back off machine, at the bottom of the drum is a very large clip slacken off and clean out fillter (looks like a bellows)
you will find a lot of muck in the filter
did this last week and its now running ok
ian
Posted on Feb 11, 2008
beltronic205
  • 1474 Answers
SOURCE: water is backing and flooding out the front from the soap drawer.
Sounds like this is the case check your hose from soap drawer that feeds drum, may need unblocked.
Posted on Apr 13, 2010
  • 1294 Answers
SOURCE: Water Leak
If possible pull out your drawer and clean it up. Reason due to clogging with detergent, etc. Refer to your manual. If you can't get the drawer out, use a tooth brush to scrub; see that brush does not fall in. The dirt can fall in. To test if clear, pour water into drawer by opening it just so the water will fall in. Try all the drawers.
And rate me pl......
Posted on Dec 02, 2007
SOURCE: Water coming from soap dispenser
Kenmore front lading washer - water is coming out under the soap dispenser. Its not going to the wahers tub.
Posted on Apr 11, 2008
  • 3 Answers
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this fi
Posted on Oct 23, 2009
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
Water pouring out of the detergent drawer
Remove the dispenser draw and pour water down the soap chute as much as you can to soften any soap causing the blockage. When the water level drops, add more water. After a while use a soft flexible rubber hose and run it down the chute up and down to remove caked soap. Once this has been achieved, run the machine on "Rinse & Spin" to clean out the drum.
Mar 19, 2014 | LG WM2101H Front Load Washer
Water leaking out of soap dispenser?
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 17, 2013 | Washing Machines
The powder will not dispense. Water is getting in because the powder is wet and clumpy but is still left in the dispenser.
I suggest you remove the soap dispenser drawer and thoroughly clean it, ensuring that the outlet at the back of the drawer where the water and soap feed into the machine are completely clear of any soap buildup.
Before you replace the drawer, ensure that the water feed into the drawer (this is a pipe or tube above the drawer slot) is not clogged with soap.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet and the water is over flowing from the soap drawer. I have already cleaned out the soap drawer and tried flushing the opening that leads into the machine with a hose. Any other...
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dish washer soap does not dissolve, whether or not I put the tablet or the pillow into the soap dispenser. Is it the soap dispenser door? Would hard water buildup create low water pressure so the soap...
The most likely causes are the you are using a tablet in a gel coating but putting the tablets into the dispenser drawer when the dispencer drawer is damp, thus causing the tablet to stick inside the housing; or, if the dispenser drawer is releasing the tablet into the bottom of the cabinet then I would say you have a problem with your water heater. In which case you would need an enginner to come and replace the heater.
Hope this is of help
Jan 25, 2011 | Maytag MDB7100AWB Dishwasher
The fabric softner is not draining during the cycle
Normally caused by undissolved soap residue. Switch off machine from mains, Remove detergent drawer from washing machine, there might be a small plastic clip that need to be levered by hand before the drawer can come out completely. Soak detergent drawer in a tub of water, rinse under tap and wash thoroughly until all soap residue has been washed away. Replace drawer.
Jan 15, 2011 | Frigidaire ATF6000ES Front Load Washer
Water is backing and flooding out the front from the soap drawer.
Apr 13, 2010 | Kenmore Elite 45986 Front Load Washer
Water coming from soap drawer
ian
Feb 08, 2008 | Ariston Technologies AWD121WH
Water Leak
I have th same problem, apparently a possible cause could be a partially blocked pump filter. Just trying to get infoon where this is and how to get to it though.
Oct 31, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint First Edition WMA22 Front Load Washer Logo
2,450 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
